How to play sound using esp32s3 and a sd card
I am trying to let the esp32s3 play a sound locally. But there is no sound coming out. It said it is compiled and uploaded, and I keep hitting RST button, but it does not help. It is also not printing out any message that used as hint in code.
Here is code.
#include "Arduino.h"
#include "Audio.h"
#include "SD.h"
#include "FS.h"
#include "SPI.h"
// I2S Pins (For your DAC/Amplifier)
#define I2S_DOUT      14
#define I2S_BCLK      11
#define I2S_LRC       10
#define I2S_SD        13  // Shutdown pin
// SD Card SPI Pins (Check your specific ESP32 board pinout)
#define SD_CS          5
#define SPI_MOSI      23
#define SPI_MISO      19
#define SPI_SCK       18
Audio audio;
    // 1. Enable Amplifier (SD Pin)
    pinMode(I2S_SD, OUTPUT);
    digitalWrite(I2S_SD, HIGH);
    // 2. Initialize SD Card
    // Note: Adjust pins if your board uses different SPI pins
    SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI);
    if (!SD.begin(SD_CS)) {
        Serial.println("Error: SD Card mounting failed!");
        while (true); // Halt if SD fails
    Serial.println("SD Card mounted successfully.");
    // 3. Setting I2S pins
    audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
    // 4. Audio Settings
    audio.setVolume(15); // 0-21
    // 5. Play from SD Card
    // Ensure the file name matches exactly what is on your card
    if(!audio.connecttoFS(SD, "/Giant_U.mp3")){
        Serial.println("File not found on SD card!");
    audio.loop();
// Optional: Audio info callback for debugging
void audio_info(const char *info){
    Serial.print("audio_info: ");
    Serial.println(info);
I moved your topic to an appropriate forum category @ricky_777.
In the future, when creating a topic please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Are you complaining about compile time, play time, or both?
I just can't play it. There is no sound. Also, the serial monitor does not print any useful information when I press RTS.
Here is the information
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce2820,len:0x10cc
load:0x403c8700,len:0xc2c
load:0x403cb700,len:0x30c0
entry 0x403c88b8
That's a completely separate issue from taking forever to compile, isn't it?
If you aren't precise in stating the nature of your problem, no one is going to be able to help you.
So, beginning again, it doesn't play. There is no sound.
All you've told is that you have an ESP32 and an SD card. Do you have a amplifier? Do you have a speaker? How is everything hooked up? Where is your schematic showing that? What SD card (module, I presuming) do you have? What amp? Did you write this code yourself? If not, where's the link to where it came from? I see your code has print statements; what do you see on your Serial Monitor? Did your SD card hookup work when you tested it individually with one of the examples from the SD library? Did your I2S hookup work when you tested it individually with one of the examples from the I2S library?
Be precise, be detailed.
Most likely your IDE setup is wrong.
Can you get your esp32 to print a hello world or something like that?
The prints your skets has are kind of useless.
after the β€œ Serial.begin(115200);” add a delay then a print.
Enable cdc on boot on your ide.
no I can't get it to print out anything.
Have a look at Bill's work at LINK
Hi @ricky_777.
When I'm having trouble with serial output, I like to do a quick check with the most simple possible sketch. If this works, then I know the problem has something to do with my real sketch. If it doesn't work, then I know the problem is not related to my sketch code. It seems maybe a little silly, but it allows me to be sure I'm focusing my troubleshooting efforts in the right direction.
Please try this experiment and then report the results:
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
  1. Copy and paste this code as a new sketch in Arduino IDE:
      Serial.println("hello");
  2. Select Sketch > Upload from the Arduino IDE menus.
    Arduino IDE will start an upload operation.
  3. Wait for the upload to finish successfully.
    :red_exclamation_mark: If it does not finish successfully, add a reply here on this forum topic to inform us of the failure and we'll investigate further.
  4. Select Tools > Serial Monitor from the Arduino IDE menus to open the Serial Monitor view if it is not already open.
Please add a reply here on this forum topic to tell us whether you now see the word "hello" being printed in the Serial Monitor's output field once a second.
This is my circuit. Also, somehow I am using ESP32 S3 which means I do have a slot for the SD card to be inserted and it is on chip. So do I still need to define the pin for the SD card reader?
The upload was successful. I think the serial monitor is also connected. But I still get nothing back. I got this when I press RST botton:
Build:Mar 27 2021
SPIWP:0xee
entry 0x403c88b8
That is not any help. Hand draw where every wire goes and take a photo of the diagram.
Your board is an esp32-s3-cam board. Make sure you have the right board selected. Also, make use of post 8.
BTW, the setup in your photo in post 10 can not print to Serial.
First configure properly the Arduino IDE.
