Actually I have googled a lot for above help, but couldn't get any specific thing. I have downloaded freeRTOS freeRTOSv702.zip and extracted the same. I copied the folder in libraries of arduino 1.0.5 IDE. Then I even add the library from sketch-> import library.
But still whenever I am trying to compile, I get errors regarding porting. SO do we have any tutorials to port the RTOS or can specific any particular things. I am using ARDUINO UNO for my learning purpose
Also It will be of great help, if anyone can provide with a sample example to confirm complilation
Regards
Nikhil
I just went to the link in this thread. Downloaded FreeRTOS20130714.zip. Extracted the FreeRTOS_AVR folder to Projects/libraries and compiled the example frBlink.ino sketch without problem.
What libraries are you trying to use and what are the errors you get?
By project folder do you mean, arduino-1.0.5/libraries/. So i downloaded the zip file you have said. I will copy the FreeRTOS folder in libraries.
Also can you share the example file pl.
nikhillife11:
No not there, look at this guide on installing libraries.
The example along with several others is include in the FreeRTOS library folder you will copy.
Actually I tried the things as the links said. But still facing some error. I have attach the logs. I see that it is not able to get FreeRTOS.h files. Not able to find why. Hope you can help me
ERROR IS AS FOLLOWS
D:\arduino-1.0.5\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -ID:\arduino-1.0.5\arduino-1.0.5\hardware\arduino\cores\arduino -ID:\arduino-1.0.5\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\Nikhil\AppData\Local\Temp\build6734853460650207127.tmp\frBlinkPrint.cpp -o C:\Users\Nikhil\AppData\Local\Temp\build6734853460650207127.tmp\frBlinkPrint.cpp.o
frBlinkPrint.ino:3:26: warning: FreeRTOS_AVR.h: No such file or directory
frBlinkPrint:10: error: 'xTaskHandle' does not name a type
frBlinkPrint.ino: In function 'void vLEDFlashTask(void*)':
frBlinkPrint:23: error: 'configTICK_RATE_HZ' was not declared in this scope
frBlinkPrint:23: error: 'vTaskDelay' was not declared in this scope
frBlinkPrint.ino: In function 'void vPrintTask(void*)':
frBlinkPrint:36: error: 'configTICK_RATE_HZ' was not declared in this scope
frBlinkPrint:36: error: 'vTaskDelay' was not declared in this scope
frBlinkPrint.ino:39: warning: only initialized variables can be placed into program memory area
frBlinkPrint.ino:43: warning: only initialized variables can be placed into program memory area
frBlinkPrint:44: error: 'blink' was not declared in this scope
frBlinkPrint:44: error: 'uxTaskGetStackHighWaterMark' was not declared in this scope
frBlinkPrint:48: error: 'freeHeap' was not declared in this scope
frBlinkPrint.ino: In function 'void setup()':
frBlinkPrint:62: error: expected primary-expression before 'signed'
frBlinkPrint:62: error: expected )' before 'signed' frBlinkPrint:70: error: expected primary-expression before 'signed' frBlinkPrint:70: error: expected )' before 'signed'
frBlinkPrint:77: error: 'vTaskStartScheduler' was not declared in this scope
frBlinkPrint.ino:80: warning: only initialized variables can be placed into program memory area
Hi
As we are in the forum dedicated to Due, I assume you are trying to use FreeRTOS on a Due.
So you have to use use the FreeRTOS_ARM library. Not the FreeRTOS_AVR one as it seems you are doing:
