A small point about this thread. The switch in the photograph is not a "limit" switch, it is a single pole changeover microswitch. Whilst it is true that such switches are often used as limit switches but they are not limited (sorry) to such use and a limit switch could be any type of switch operated at the limit of movement of some kind of mechanical component to stop its movement at that point.
UKHeliBob:
A2 is a digital pin when used correctly.
And the difference is how they are actuated. Some have a tiny push button. Some have a leaf like yours, but with a roller on the end and some are just like yours. The roller type may follow a cam and actuate at a certain cam rotation to time a function. Some, like yours, may be actuated by something with a range of contact point positions. And there are probably other designs.
