With Google -> Search the datasheet: Atmel atmega640/v-1280/v-1281/v-2560/v-2561/v
On page 96, chapter 13.4.2, you'll find all the register addresses to achieve the ports A, B, C, D, E, F, G, H, J, K, L
Attention: The Board Mega 2560 is full wired (8bits) only for Port A,B,C, L
Port F, K are shared with Analog Adc0…Adc15
Port D, E, G, H are partially or not wired on the Board Atmega 2560
PORTA – Port A Data Register write one byte
DDRA – Port A Data Direction Register -> setect Port direction ‘0’ Input, ‘1’ output
PINA – Port A Input Pins Address read one byte
Since the standard Arduino instruction set does not have a Port write or Port read instruction, you must use pointers that target registers to read or write to a Port.
These 3 registers aim Port A for board Arduino 2560 or .UNO
Port A I/P Register address 0x22 read one byte full on port A
Port A Direction Register address 0X21 set Direction Input / Output
Port A O/P Register address 0x20 write one byte full on port A
Sketch example with Read Port A and Write Port B
To test -> prepare one wire connected to GND
Touch the Pin 22 … 29 with the wire see the Monitoring Display to check if PortA display ‘0’ ‘1’
#include <Arduino.h>
// define all pointer Port A, Port B
volatile unsigned char* INportA = (unsigned char*) 0x20; // define pointer name INportA on register address 0x20
volatile unsigned char* portDDRA = (unsigned char*) 0x21; // define pointer name portDDRA on register address 0x21
volatile unsigned char* OUTportA = (unsigned char*) 0x22; // define pointer name OUTportA on register address 0x22
volatile unsigned char* INportB = (unsigned char*) 0x23; // define pointer name INportA on register address 0x23
volatile unsigned char* portDDRB = (unsigned char*) 0x24; // define pointer name portDDRA on register address 0x24
volatile unsigned char* OUTportB = (unsigned char*) 0x25; // define pointer name OUTportA on register address 0x25
byte a; // variable in RAM
Serial.begin(9600); // prepare serial monitor 9600 bauds
pinMode (22, INPUT_PULLUP); // Selectt all 8 bits Port A with PullUp (Pin 22....29)
pinMode (23, INPUT_PULLUP);
pinMode (24, INPUT_PULLUP);
pinMode (25, INPUT_PULLUP);
pinMode (26, INPUT_PULLUP);
pinMode (27, INPUT_PULLUP);
pinMode (28, INPUT_PULLUP);
pinMode (29, INPUT_PULLUP);
*portDDRA = 0x00; // Set direction PortA INPUT '0'
*portDDRB = 0xFF; // Set direction PortB OUTPUT '1'
// prepare one wire connected to GND
// touch the Pin 22 … 29 with the wire see the Monitoring Display to check if PortA display ‘0’ ‘1’
a = *INportA; // READ byte PORTA digital pin A0(pin22)... A7(pin29) Arduino Mega 2560
Serial.println("Hello_IN Port A: "); // sort sur serial monitoring console
Serial.println(a,BIN); // Print out on serial monitoring console Binar format
delay (1000);
*OUTportB = a; // WRITE byte value..
delay (1000);
This sketch has been tested with success
