I want to measure the time elapsed between two pulse on two different interupt pin. My reading is somehow accurate when using micros(). But reading is erratic when using hardware timer TCNT1. When interrupt in one pin timer 1 start and interupt in second pin timer1 stop. Then I am reading Tcnt1. Up to 255 microsecond timing is correct. Prescale is 8.
Perhaps if you post your code?
Please use code tags.
using arduino uno r3 board and interrupt pin 2(int0)and pin3(int1)
volatile unsigned int timer1_counter;//integer to store the value of timer
volatile boolean state1;
boolean state2;
attachInterrupt(0, starttimer, RISING);//pin2 interrupt
attachInterrupt(1, stoptimer, RISING); //pin3 interrupt
state1=0;
state2=0;
TCCR1A = 0;//timer1 in normal mode
TCCR1B = 0;//timer1 in normal mode
timer1_counter = 0;
TCNT1 = timer1_counter; //making intial time counter to zero
void starttimer()
TCCR1B |= (1<< CS11);//start the timer with prescaler 8
void stoptimer()
TCCR1B |= (0<< CS11);//stop the timer
timer1_counter = TCNT1;//read and store the counter value
state1=1; // time measrurement complete
if ((state1==1) and (state2==0)){ //
Serial.print(timer1_counter);
state2=1;
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
if ((state1=1) and (state2=0)){ //
Those are assignment operators '=', not comparison operators '=='.
Changed the code with == but the same problem is coming. Up to 255 counts it comes correctly.beyond that it erratic.
amubgr:
TCCR1B |= (0 << CS11); //stop the timer
OR-ing with 0 will not set the bit to 0 so that won't stop the timer.
To clear that bit use:
TCCR1B &= ~(1 << CS11); //stop the timer
Thanks sir. Actually I was working with mikrobasic compiler. Recently I decided to shift to arduino due to its open support. Now I am learning the syntax. I will try the correct code as suggested by u.
