I've got the code working but it's not behaving the way I expect. Can anybody tell me what I'm doing wrong or how to improve it?
First of all, I thought the arduino would sleep when it executes the LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF); instruction but it doesn't, at least not right away. After that line, it executes another few lines before falling asleep. (More specifically, the code moves into a function and then falls asleep in the middle of printing characters to the Serial Monitor - see below.)
Second of all, after uploading the code the arduino goes to sleep before it finishes executing the setup code, even though the LowPower instruction doesn't appear until inside the loop function! (Is this something the LowPower library makes happen by default?)
Here's how it unfolds: I first upload the code. I expect to see "Hello World!" and then "Starting loop()" on the Serial Monitor since the first instruction is in setup, and the second occurs before the LowPower instruction. Instead the arduino immediately goes into low power mode and I only see this on Serial Monitor:
Now I press the Power button. The LED_BUILTIN turns on for just a split second. I see this on Serial Monitor...
⸮⸮llo World!
Starting loop()
Just passed LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF)
Inside do
...And the arduino goes back to sleep.
So I press the Power button again. Serial Monitor shows me...
Z⸮gTheThingLoop()
Exiting doingTheThingLoop()
Starting loop()
Inside doingTheThingLoop()
...and this time the arduino stays on. The LED_BUILTIN stays lit. I can press the Blink button and the blinking starts and stops like it should. This Blink button is working just fine.
Now I click the power button again to turn it off. The arduino turns off and I see this on Serial Monitor:
I click the power button again to turn it back on. The arduino stays on. This is on Serial Monitor:
⸮⸮iting doingTheThingLoop()
Starting loop()
Inside do
Here's my actual code.
/* Code to make arduino go into and out of low power mode.
* 2 buttons attach to arduino.
* Power button:
* - makes arduino go into/come out of low power mode
* - push button connects pin 3 to ground
* Blink button:
* - makes an RGB LED start & stop flashing in sequence.
* - push button connects Vcc to pin 2 with 10k resistor to ground
* RGB LED is common cathode, 100ohm resistors connect pins 7-9 to leads.
#include "LowPower.h"
// Outputs for RGB LED
int greenPin = 7;
int bluePin = 8;
int redPin = 9;
//Pins for button interrupts.
const byte interruptPowerPin = 3;
const byte interruptBlinkPin = 2;
// Flags for the doingTheThingLoop().
volatile boolean makeBlinkFlag = false; // false == NO; true == YES
volatile boolean powerFlag = false; // false == NO; true == YES
void interruptPower()
powerFlag =!powerFlag;
if(powerFlag) //If power being turned on
digitalWrite(LED_BUILTIN, HIGH); //Turn on LED_BUILTIN
void interruptBlink()
makeBlinkFlag =!makeBlinkFlag;
void doingTheThingLoop()
Serial.println("Inside doingTheThingLoop()");
while(powerFlag) // If power is on, do next thing. If it's not, exit this function to return to loop.
//Serial.println(" PowerFlag == TRUE");
while(makeBlinkFlag) //If the makeBlink button has been pressed, do these instructions.
Serial.println(" Now doing the thing!");
digitalWrite(greenPin, HIGH);
digitalWrite(greenPin, LOW);
digitalWrite(bluePin, HIGH);
digitalWrite(bluePin, LOW);
digitalWrite(redPin, HIGH);
digitalWrite(redPin, LOW);
Serial.println("Exiting doingTheThingLoop()");
// Establish RGB LED leads
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
pinMode(redPin, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);
pinMode(interruptBlinkPin, INPUT);
attachInterrupt(digitalPinToInterrupt(interruptBlinkPin), interruptBlink, RISING);
Serial.println("Hello World!");
Serial.println("Starting loop()");
pinMode(interruptPowerPin, INPUT_PULLUP); //Interrupt only works if pin goes LOW
attachInterrupt(digitalPinToInterrupt(interruptPowerPin), interruptPower, LOW); // This only works for LOW
//------This is where I expected the arduino to power off.------
Serial.println("Just passed LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF)");
doingTheThingLoop();
digitalWrite(LED_BUILTIN, LOW);
