How to reduce String Memory Demand
My example sketch uses strings which can hog lots of memory. I'm looking for ways to reduce that memory demand. In the sketch below, memory isn't a problem, but with other sketches, it is.
I tried char with multiple characters, but that didn't work.
Any ideas? My example sketch appears below.
//Add, subtract and multiply calcutator for two input numbers. Input and output via the Serial Monitor. See note after the sketch.
//Multiply doesn't work with large input numbers.                        DE 1/29/20
//When using Quit, the IDE will ask for save or not.
int numberA;
int numberB;
int sum;
int diff;
int product;
int both;
String msgA="Enter 1st number, then hit Enter.";
String msgB="Enter 2nd number, then hit Enter.";
String msgA1="Your 1st number is: ";
String msgB1="Your 2nd number is: ";
Serial.println("A simple add/multiply/total calcutator. No large numbers please.");
} //end setup
//get 1st number
Serial.println(msgA);
while (Serial.available()==0){//waiting for 1st number
numberA=Serial.parseInt();//get 1st number
Serial.print(msgA1);
Serial.println(numberA);
//get 2nd number
Serial.print(msgB);
while (Serial.available()==0){//waiting for 2nd number
numberB=Serial.parseInt();//get 2nd numbe
Serial.print(msgB1);
Serial.println(numberB);
//calculate answers
sum = numberA+numberB;
delay(100);
diff = numberA-numberB;
delay(100);
product = numberA*numberB;
delay(100);
both = sum+product;
//print answers
Serial.print("The SUM is ");
Serial.println(sum);
Serial.print("The DIFFERENCE is ");
Serial.println(diff);
Serial.print("The PRODUCT is ");
Serial.println(product);
Serial.print("Added TOGETHER (sum + product) they are ");
Serial.println(both);
//NOTE !! Serial-monitor must be set to NO LINE ENDING to avoid extra zeros in the println(number) display. Also use auto scroll.
Use c-strings … null-terminated char arrays:
https://www.tutorialspoint.com/cprogramming/c_strings.htm
http://www.cplusplus.com/reference/cstring/
ardocman:
My example sketch uses Strings which can hog lots of memory.
The F() macro would help here.
If string is constant, use PROGMEM or F() macro to save RAM memory.
If string is not constant, and if you want to use String object, use String.reserve() to avoid the memory leak and fragment issue.
The evil of Arduino Strings...
TheMemberFormerlyKnownAsAWOL:
Thanks! Your simple F() macro suggestion worked very well. My dynamic memory went from 1,318 ------> 596 bytes.
While using F() macro is the correct answer here, if you go further take a look at my SafeString library available via the
Arduino library manager. (detailed tutorial here)
SafeStrings are debuggable and safe and much more robust then c-strings and do not have the memory fragmentation and the odd errors of Arduino Strings.
