How to remove sound comming from servo motor?
When ever i move the servo motors from the arduino, it produces sound. I don't want the servos to make this sound. How can i remove this sound. As i think this sound must be coming from the gears used inside the servo motor, but how can i silent those sound?
Some kind of noise-cancelling DSP?
What kind of servos are you using? If cheap and cheerful then you get noise, plastic gears or metal? Open the servo and pack lots of grease in around the gears.
Any other ideas!
Hope it helps, regards.
Mel.
You have not given us much info, and without it we are simply guessing.
Some sounds form some servos is gear noise.
Some servos make a noticeable high pitched whine from the electronics.
Almost all servos will make some noise if they are under load, holding up something heavy.
Which servo do you have?
Under which conditions does it make noise?
Is the servo under load, with the output tied to something heavy?
Or is it completely free to move?
Motors with gears are always noisy. Cheap gears are the noisiest by far.
