This (attached) is a sketch of a clock + temperature sensor DHT22 using an esp8266 that gets the data (Time and Date) from a local HTTP server but, I would like to use an NTP server (because I live in another country - Brazil) to get the data but, I don't have enough knowledge for it, so could someone kindly, by kindness, instruct me what should I change in the sketch to do this?
The code was taken from here: ESP8266 IoT room thermometer - part 1 - Machina Speculatrix
Sorry, English is not my native language!
My early thanks,
Daniel
IoT_room_thermometer.ino (15.7 KB)
Daniel:
Adapting your ESP8266 program to use NTP time is almost trivial now that the ESP8266 core has been updated with some of the ESP32 code.
Here is a program I threw together for my own reference a few months ago. You will have to do some research to find out how to modify the setenv(...) function parameters for your time zone.
// Minimal code to implement NTP update of timekeeping on an ESP8266
// This code uses EspressIF functions introduced with the ESP32. They work on
// recent versions of the ESP8266 core as well.
// Date and time information is output on the serial monitor.
// Time is derived from an NTP time server
// Program information
char programName[] = "NTP_Minimal_Updated.ino";
char versionNumber[] = "v07";
char programDate[] = "2019-05-04";
char programAuthor[] = "Donald Weiman";
// Version information
// v01 - cobbled together from various example programs
// v02 - clean up code and comments
// v03 - implement settimeofday() callback (indicating NTP update)
// v04 - save time when NTP update occurred
// v05 - move display of time out of loop()
// v06 - specify interval between time displays (remove delay() from loop())
// v07 - remove vestigial code from previous versions
// Required libraries
#include <ESP8266WiFi.h>
#include <time.h>
#include <coredecls.h> // required for settimeofday_cb()
const char* ssid = "..."; // put your info here
const char* pass = "...";
// Timing parameters
int data_update_minutes = 1; // measurement interval in minutes
time_t present_timestamp;
time_t previous_timestamp = 0;
// make sure the ESP8266 WiFi functions are enabled
WiFi.mode(WIFI_STA); // use only the WiFi 'station' mode
// display sign-on message - useful to determine exactly which version is running
Serial.print(programName);
Serial.print(" ");
Serial.print(versionNumber);
Serial.print(" ");
Serial.print(programDate);
Serial.print(" ");
Serial.print(programAuthor);
// minimal code to log onto a local WiFI network
WiFi.begin(ssid, pass); // send credentials
while (WiFi.status() != WL_CONNECTED) // wait for connection
Serial.print(".");
// implement NTP update of timekeeping (with automatic hourly updates)
configTime(0, 0, "0.pool.ntp.org");
// info to convert UNIX time to local time (including automatic DST update)
setenv("TZ", "EST+5EDT,M3.2.0/2:00:00,M11.1.0/2:00:00", 1);
// register a callback (execute whenever an NTP update has occurred)
settimeofday_cb(time_is_set);
Serial.println("\nSetup done");
present_timestamp = time(nullptr);
if (present_timestamp >= previous_timestamp + (60 * data_update_minutes))
previous_timestamp = present_timestamp;
displayDateAndTime();
void time_is_set (void)
// callback routine - arrive here whenever a successful NTP update has occurred
struct tm *tmp ; // NOTE: structure tm is defined in time.h
char UPDATE_TIME[50]; // buffer for use by strftime()
// display time when NTP update occurred
time_t tnow = time(nullptr); // get UNIX timestamp
tmp = localtime(&tnow); // convert to local time and break down
strftime(UPDATE_TIME, sizeof(UPDATE_TIME), "%T", tmp); // extract just the 'time' portion
Serial.print("\n-------- NTP update at ");
Serial.print(UPDATE_TIME);
Serial.println(" --------");
void displayDateAndTime()
Serial.print(present_timestamp); // display system time as UNIX timestamp
// use ctime() to convert the system (UNIX) time to a local date and time in readable form
// NOTE: 'ctime' produces a output in a specific format that looks
// like --> Fri Mar 22 12:11:51 2019 -there is also a newline (\n) appended
Serial.print(" ");
Serial.print(ctime(&present_timestamp)); // convert timestamp and display
char FORMATTED_TIME[50]; // filled by strftime()
// convert the system (UNIX) time to a local date and time in a configurable format
tmp = localtime(&present_timestamp); // break down the timestamp
// use strftime() to display the date and time in some other formats
// https://www.geeksforgeeks.org/strftime-function-in-c/
// the following gives output in this form --> 03/22/19 - 12:11 pm EDT
// where %x --> writes localized date representation
// %I --> writes hour as a decimal number, 12 hour clock (range [01,12])
// %M --> writes minute as a decimal number (range [00,59])
// %P --> writes localized a.m. or p.m. (locale dependent)
// %Z --> time zone abbreviation name
strftime(FORMATTED_TIME, sizeof(FORMATTED_TIME), "%x - %I:%M%P %Z", tmp);
Serial.println(FORMATTED_TIME);
// the following gives output in this form --> 2019-03-22 12:11:51
// %F --> equivalent to "%Y-%m-%d" (the ISO 8601 date format)
// %T --> equivalent to "%H:%M:%S" (the ISO 8601 time format)
strftime(FORMATTED_TIME, sizeof(FORMATTED_TIME), "%F %T", tmp);
EDIT: Note that this program uses time.h not Time.h (lower case).
Don
Hi Don
Thanks for the sample program; I will try, although I have no concrete idea how to adapt this to my sketch! But thanks for the help
Dan
