How to request input from the Serial Monitor
I am coming from python and usually you can just write for example input(int("What's your age?")), but here I don't know how to do it, I researched a bit but I didn't understand, can someone help, please! Here is the code(and I need help at math too):
#include<math.h>
#include<Servo.h>
Servo test;
Servo test1;
int xy = 50;
float y;
float x;
float post; //the angle of the first servo
float post1; //the angle of the second servo
float h; //lenght of the needed height for the arm to be able to touch the object
float d; //the distance to the object
int b = 50; //lenght of the arm
  test.attach(4);
  test1.attach(5);
  test.write(0);
  test1.write(0);
  x = input(float("X=? "));
  y = input(float("Y=? "));
  d = sqrt(sq(xy-x)-sq(xy-y));
  post = asin((xy-x)/d);
It's all documented, here is a part of it.
https://docs.arduino.cc/language-reference/en/functions/communication/serial/available/
I think I would approach something like what you're after by starting simple, using wasd to move the servo in increments of maybe 1 degree either direction for a and d, and maybe 10 degrees for w and s.
What follows is tested only in Serial and should work with servos that in my testing, I didn't bother to use.
Set your serial monitor to 115200 baud, no line ending. Good luck.
#include <math.h>
#include <Servo.h>
Servo test;
Servo test1;
char mode;
int pos;   // to store servo position
int pos1;  // to store other servo position
int xy = 50;
float y;
float x;
  Serial.begin(115200);  // 9600 like you had is meh. 115200 is less meh
  test.attach(4);
  test1.attach(5);
  Serial.println(F("charDrivenServoStateMachine\n\n"));
  Serial.println(F("Type 0 to set servos to zero"));
  Serial.println(F("Type w,a,s,d to rotate servo shaft"));
  Serial.println(F("Use space bar to center servos\n"));
  mode = '0';  // start state variable at mode 0
  modeZero();  // let us know and init devices to off
  if (Serial.available() > 0) {
    mode = Serial.read();
    switch (mode) {
      case 'a':
        pos -= 1;
        pos1 -= 1;
        modeOne();
      case 'd':
        pos += 1;
        pos1 += 1;
        modeTwo();
      case 'w':
        pos += 10;
        pos1 += 10;
        modeThree();
      case 's':
        pos -= 10;
        pos1 -= 10;
        modeFour();
      case ' ':  // space bar to zero (center) servos at 90 degrees
        pos = 90;
        pos1 = 90;
        modeCenter();
      case '0':
        pos = 0;
        pos1 = 0;
        zero();
    // next four lines are to constrain (protect) your servos
    if (pos >= 175) pos = 175;  // set 175 to 180 for full range with slight risk
    if (pos1 >= 175) pos1 = 175;
    if (pos <= 5) pos = 5;  // set 5 to 0 for full range with slight risk
    if (pos1 <= 5) pos1 = 5;
    Serial.print("servo 1:");
    Serial.print(pos);
    Serial.print(" servo 2:");
    Serial.print(pos1);
    Serial.print(" degrees\n");
void modeCenter() {
  Serial.print("CENTER SERVOS ");
  centerServos();
void modeZero() {
  zero();
void modeOne() {
  Serial.print("ONE DEG LEFT ");
  oneDegLeft();
void modeTwo() {
  Serial.print("ONE DEG RIGHT ");
  oneDegRight();
void modeThree() {
  Serial.print("TEN DEG LEFT ");
  tenDegLeft();
void modeFour() {
  Serial.print("TEN DEG RIGHT ");
  tenDegRight();
void centerServos() {
  test.write(pos);
  test1.write(pos1);
void zero() {
  test.write(pos);
  test1.write(pos1);
void oneDegLeft() {
  test.write(pos);
  test1.write(pos1);
void oneDegRight() {
  test.write(pos);
  test1.write(pos1);
void tenDegLeft() {
  test.write(pos);
  test1.write(pos1);
void tenDegRight() {
  test.write(pos);
  test1.write(pos1);
output
> 12 24
12
24
> 99 14
99
14
const char *prompt = "> ";
void loop ()
    if (Serial.available ())  {
        char buf [90];
        int  n = Serial.readBytesUntil ('\n', buf, sizeof(buf)-1);
        buf [n] = '\0';
        Serial.println (buf);
        // do something with buf
        int x, y;
        sscanf (buf, "%d %d", &x, &y);
        Serial.println (x);
        Serial.println (y);
        Serial.print (prompt);
void setup ()
    Serial.begin (9600);
Thank you, it is an idea, but I wanted to only give to the arm a pair of coordinates and to let it touch a point
Spend some time with this great page. Sure has helped me in the past.
@Robin2's tutorial is definitely a must-read. However, there are libraries for everything else — is there no library for simple serial input tasks? I am familiar with more advanced libraries like cmdArduino, but is there a library that just implements something equivalent to scanf(), gets() and getc()?
I can't say from experience. I find @Robin2's techniques have always covered my needs.
in my experience, your better off capturing an entire line and then extracting the parts you're interested in. see the code i posted above
sscanf.
So that's what I've been looking for....
