How do i detect input from a laptop/desktop computer , such as a line or string of text?
ok so if i input something like "turn on led" and put it into the Arduino uno r3, it turns on an LED. how would i do it?
A great place to start learning how to do that is the Arduino Serial Input Basics tutorial.
Hint: simpler commands make the programming easier, like
LED 1
or
LED 0
to turn on and off the LED, respectively.
Here are several examples on to do it from @Robin2 and others, impplemented as Wokwi simulations:
I would suggest using a library like cmdArduino:
https://docs.arduino.cc/libraries/cmdarduino/
how about
const int ledPin    = 13;    // Pin for LED
enum { Off = HIGH, On = LOW };
void loop ()
    if (Serial.available ())  {
        char buf [90];
        int  n = Serial.readBytesUntil ('\n', buf, sizeof(buf)-1);
        buf [n] = '\0';             // terminate with nul
        if (! strcmp (buf, "turn on led"))
            digitalWrite (ledPin, On);
void setup () {
    Serial.begin (9600);
    pinMode      (ledPin,    OUTPUT);
    digitalWrite (ledPin,    Off);
    Serial.println (Off);
so now you want a command to turn the led off
void loop ()
        char buf [90];
        if (! strcmp (buf, "turn on led"))  {
            Serial.println ("  on");
        else if (! strcmp (buf, "turn off led"))  {
            Serial.println ("  off");
void setup () {
    Serial.println ("cmds: on and off");
that's a lot of typing, and what if there's more than one LED, and what if the pins are not LED. what about a more generic cmd that takes a pin # and on/off
const byte Pins []  = { 13, 12, 11, 10 };
const int  Npin        = sizeof(Pins);
void loop ()
        char buf [90];
        char cmd [9];
        int  pin;
        sscanf (buf, "%s %d", cmd, &pin);
        if (! strcmp (cmd, "on"))
            digitalWrite (pin, On);
        else if (! strcmp (cmd, "off"))
            digitalWrite (pin, Off);
        Serial.print   ("    pin ");
        Serial.print   (pin);
        if (Off == digitalRead (pin))
void setup () {
    for (int n = 0; n < Npin; n++)  {
        pinMode      (Pins [n], OUTPUT);
        digitalWrite (Pins [n], Off);
    Serial.println ("cmds: cmd #");
