hello. I am working with a couple of Yuns exchanging data via wifi. Sometime happens that for any reason (also my "live" intervention on the hw, sensors, etc...) the wifi i/f fails. The white and blue led are off. I cannot connect any more. The i/f is not either in the live nor in the AP mode.
I am looking for a "simple" and linear procedure to restart the wifi i/f.
I suppose that the wifi configuration is still OK, so it should not be necessary to pass through the wifi reset/configure steps. Is it true ?? Just pressing the wifi reset button for a couple of seconds does not work.
Also switching down/up the board does not work.
A problem that may be perhaps connected is that sometimes, after the configuration (OK) from AP mode, the wifi i/f does not come up. How can I start it at this point ???
Thanks in advance for any clarification
I try to explain better :
After many trials I have the following behaviour:
- system working fine, wifi up, connected.
- system switched off
- system switched on
- the wifi i/f does not come up
- as I connect the etherned cable (just connect - no operations) also the wifi i/f is started.
-I disconnect the cable and the system is working fine again
Of course what I would like to have is that as the system is switched on again the wifi i/f is started.
thanks
Mine restarts the WiFi automatic and no issues after a power loss.
What was the last sketch you sent to the YUN and could you post it here please
Use code tags ( </> ) for the sketch or any other error / log messages.
I currently have “Arduino | OpenWRTYun Attitude Adjustment 1 | Load: 0.45 0.29 0.13” on mine btw.
And the following packages (although your config may be slightly different)
Package name Version
Remove avahi-daemon 0.6.31-5
Remove avahi-dnsconfd 0.6.31-5
Remove avahi-utils 0.6.31-5
Remove avrdude 5.11.1-r1138-1
Remove base-files 118.2-r42647
Remove blkid 2.21.2-1
Remove block-mount 0.2.0-9
Remove busybox 1.19.4-6
Remove cpu-mcu-bridge 1.5.1-2
Remove curl 7.29.0-1
Remove dbus 1.4.14-2
Remove distribute 0.6.21-1
Remove dnsmasq 2.66-2
Remove dropbear 2011.54-2
Remove firewall 2013-06-29
Remove gnupg 1.4.12-1
Remove hotplug2 1.0-beta-4
Remove iptables 1.4.10-5
Remove iw 3.14-1
Remove jshn 2013-10-19-734d28eb1a46358743cf8837c91e5d46695c3b91
Remove kernel 3.3.8-1-openwrtyun1
Remove kmod-ath 3.3.8+2014-05-22-1
Remove kmod-ath9k 3.3.8+2014-05-22-1
Remove kmod-ath9k-common 3.3.8+2014-05-22-1
Remove kmod-cfg80211 3.3.8+2014-05-22-1
Remove kmod-crypto-aes 3.3.8-1
Remove kmod-crypto-arc4 3.3.8-1
Remove kmod-crypto-core 3.3.8-1
Remove kmod-crypto-hash 3.3.8-1
Remove kmod-crypto-manager 3.3.8-1
Remove kmod-fs-ext4 3.3.8-1
Remove kmod-fs-hfs 3.3.8-1
Remove kmod-fs-hfsplus 3.3.8-1
Remove kmod-fs-ntfs 3.3.8-1
Remove kmod-fs-reiserfs 3.3.8-1
Remove kmod-fs-vfat 3.3.8-1
Remove kmod-fuse 3.3.8-1
Remove kmod-gpio-button-hotplug 3.3.8-1
Remove kmod-i2c-core 3.3.8-1
Remove kmod-ipt-conntrack 3.3.8-1
Remove kmod-ipt-core 3.3.8-1
Remove kmod-ipt-nat 3.3.8-1
Remove kmod-ipt-nathelper 3.3.8-1
Remove kmod-leds-gpio 3.3.8-1
Remove kmod-ledtrig-default-on 3.3.8-1
Remove kmod-ledtrig-netdev 3.3.8-1
Remove kmod-ledtrig-timer 3.3.8-1
Remove kmod-lib-crc-ccitt 3.3.8-1
Remove kmod-lib-crc16 3.3.8-1
Remove kmod-loop 3.3.8-1
Remove kmod-mac80211 3.3.8+2014-05-22-1
Remove kmod-nls-base 3.3.8-1
Remove kmod-nls-utf8 3.3.8-1
Remove kmod-ppp 3.3.8-1
Remove kmod-pppoe 3.3.8-1
Remove kmod-pppox 3.3.8-1
Remove kmod-scsi-core 3.3.8-1
Remove kmod-usb-core 3.3.8-1
Remove kmod-usb-storage 3.3.8-1
Remove kmod-usb2 3.3.8-1
Remove kmod-video-core 3.3.8-1
Remove kmod-wdt-ath79 3.3.8-1
Remove libassuan 2.0.2-1
Remove libavahi 0.6.31-5
Remove libavahi-client 0.6.31-5
Remove libavahi-dbus-support 0.6.31-5
Remove libblkid 2.21.2-1
Remove libblobmsg-json 2013-10-19-734d28eb1a46358743cf8837c91e5d46695c3b91
Remove libbz2 1.0.6-1
Remove libc 0.9.33.2-1
Remove libcurl 7.29.0-1
Remove libcyassl 1.6.5-1
Remove libdaemon 0.14-2
Remove libdbus 1.4.14-2
Remove libelf 0.8.13-1
Remove libexpat 2.0.1-1
Remove libffi 3.0.10-1
Remove libftdi 0.19-1
Remove libgcc 4.6-linaro-1
Remove libgcrypt 1.5.0-1
Remove libgdbm 1.9.1-2
Remove libgnutls 2.8.6-2
Remove libgpg-error 1.9-1
Remove libgpgme 1.3.1-1.dh1
Remove libip4tc 1.4.10-5
Remove libip6tc 1.4.10-5
Remove libiwinfo 44
Remove libiwinfo-lua 44
Remove libjson 0.11-2
Remove libjson-c 0.11-2
Remove libjson-script 2013-10-19-734d28eb1a46358743cf8837c91e5d46695c3b91
Remove liblua 5.1.4-8
Remove libncurses 5.7-5
Remove libnl-tiny 0.1-3
Remove libopenssl 1.0.1h-1
Remove libpcre 8.11-2
Remove libpthread 0.9.33.2-1
Remove libreadline 5.2-2
Remove librt 0.9.33.2-1
Remove libubox 2013-10-19-734d28eb1a46358743cf8837c91e5d46695c3b91
Remove libubus 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8
Remove libubus-lua 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8
Remove libuci 2013-06-11.1-1
Remove libuci-lua 2013-06-11.1-1
Remove libusb 0.1.12-3
Remove libusb-1.0 1.0.9-1
Remove libuuid 2.21.2-1
Remove libxtables 1.4.10-5
Remove lua 5.1.4-8
Remove luci 0.11+svn10537-1
Remove luci-app-arduino-webpanel 1.5.4-1
Remove luci-app-firewall 0.11+svn10537-1
Remove luci-i18n-english 0.11+svn10537-1
Remove luci-lib-core 0.11+svn10537-1
Remove luci-lib-ipkg 0.11+svn10537-1
Remove luci-lib-json 0.11+svn10537-1
Remove luci-lib-nixio 0.11+svn10537-1
Remove luci-lib-sys 0.11+svn10537-1
Remove luci-lib-web 0.11+svn10537-1
Remove luci-mod-admin-core 0.11+svn10537-1
Remove luci-mod-admin-full 0.11+svn10537-1
Remove luci-proto-core 0.11+svn10537-1
Remove luci-proto-ppp 0.11+svn10537-1
Remove luci-sgi-cgi 0.11+svn10537-1
Remove luci-theme-base 0.11+svn10537-1
Remove luci-theme-bootstrap 0.11+svn10537-1
Remove luci-theme-openwrt 0.11+svn10537-1
Remove mtd 18.1
Remove nano 2.2.6-1
Remove netifd 2013-07-16-2674941b06c1ec67f1aff1bff9212e1372106641
Remove opkg 618-3.dh1
Remove ppp 2.4.5-10
Remove ppp-mod-pppoe 2.4.5-10
Remove px5g 1
Remove python 2.7.3-2
Remove python-bzip2 2.7.3-2
Remove python-json 3_4-1
Remove python-mini 2.7.3-2
Remove python-openssl 2.7.3-2
Remove rng-tools 3-2
Remove spacebrew 2.3.0-1
Remove swap-utils 2.21.2-1
Remove swconfig 10
Remove temboo 1.1.0-1
Remove terminfo 5.7-5
Remove triggerhappy 0.3.4-1
Remove uSDaemon 1.0.0-1
Remove uboot-envtools 2012.04.01-1
Remove ubus 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8
Remove ubusd 2013-08-08-b20a8a01c7faea5bcc9d34d10dcf7736589021b8
Remove uci 2013-06-11.1-1
Remove uhttpd 2012-10-30-e57bf6d8bfa465a50eea2c30269acdfe751a46fd
Remove uhttpd-mod-lua 2012-10-30-e57bf6d8bfa465a50eea2c30269acdfe751a46fd
Remove uhttpd-mod-tls 2012-10-30-e57bf6d8bfa465a50eea2c30269acdfe751a46fd
Remove uhttpd-mod-ubus 2012-10-30-e57bf6d8bfa465a50eea2c30269acdfe751a46fd
Remove usbutils 005-1
Remove wget 1.13.4-1
Remove wireless-tools 29-5
Remove wpad-mini 20131120-1
Remove yun-conf 1.2.0-2
Remove yun-scripts 1.3-1
Remove zlib 1.2.7-1
OOPS OK firmware version "OpenWRTYun Attitude Adjustment 1 / LuCI 0.11 Branch (0.11+svn10537)"
hi. To be sure that it was not any arduino fault I emptied the sketch. Only an empty setup and loop. The problems still persists. After a power loss Linux does not restart automatically the wifi.
For the moment I apparently solved the problem following the quick and dirty suggestion of msssltd, topic : WLAN issues August 18 2014 in the Forum.
I put in the crontab
1 * * * * /init.d/network reload
It looks stable enough. But shouldn't the system do this job ??
BTW : I must say that the Yun board is located behind a wifi repeater, with an average signal strength of 65-70 %.
