How to return a value from a void function and use it inside the void loop?
Goal:
I want the variable tweet (which outputs either HIGH or LOW inside the void print() function) to turn on and off the LED_BUILTIN.
Restriction:
The if statement "producing" the tweet must run outside of the void loop().
Problem:
It seems that the void print() function does not return / expose the variable tweet inside the void loop(). The only thing what the serial monitor shows is Serial.println(val); which is 0.
What am I missing / misunderstanding here? Thank you for your help.
int intPressure = 11;
int tweet = 0;
int val = 0;
void print() {
  if(intPressure != 0)
    Serial.println("HIGH");
    tweet = HIGH;
    Serial.println("LOW");
    tweet = LOW;
  void print();
  val = digitalRead(LED_BUILTIN);
  digitalWrite(LED_BUILTIN, tweet);
  Serial.println("---");
You have an endless loop when you call print() from the print() function. (It is called in the return statement)
@KeithR
Thanks, I removed the return print() from the If statement inside the void print() function.
@Delta_G
Thank you for your suggestions.
I followed your examples
int intPressure = 12;
int tweet = 0;
int val = 0;
void print() {
    tweet = HIGH;
    tweet = LOW;
   return tweet;
  int tweetStatus = print();
  digitalWrite(LED_BUILTIN, tweetStatus);
and got 2 error messages :
Error A:
In function 'void print()':
test_bed:21: error:
return-statement with a value, in function returning 'void' [-fpermissive]
    return tweet;
Error B:
In function 'void loop()':
test_bed:26: error:
void value not ignored as it ought to be
exit status 1
Despite the explanations regarding the error messages below, I don't understand them quite, yet:
Error A
It means a function is declared to return nothing (void) but you are assigning the return code to a variable.
source: void value not ignored as it ought to b - C++ Forum
Error B
The error means that in your function:
void* foo(...);
You have a statement:
return;
But the compiler expects a value to be provided:
return myVoidPtr;
source: c++ - error: return-statement with no value, in function returning ‘void*’ [-fpermissive] - Stack Overflow
Are the error messages saying that the return statement return tweet returns something that is not there?
@Delta_G
Your correction made the code work, thanks.
And the global variable thing made me think about how to go on with the next problem, thank you.
I just tried to implement this code in another greater code block.
// Print the data extracted from the JSON
void printUserData(const struct UserData* userData) {
  int tweet = 0;
  int number = 1023;
  Serial.print("data = ");
  Serial.println(userData->pressure);
  int intPressure = atoi(userData->pressure);
  Serial.print("intPressure = ");
  Serial.println(intPressure);
  //if (*(userData->pressure) == number)  // ==number brings HIGH and !=number brings LOW
  int print() {
    tweet = HIGH;
    tweet = LOW;
   return tweet;
  // tweetStatus makes LED_BUILTIN either HIGH or LOW
The output is the following error message:
test_bed: In function 'void printUserData(const UserData*)':
test:175: error: a function-definition is not allowed here before '{' token
test_bed:239: error: expected '}' at end of input
exit status 1
According to the error above, you cannot place the function int(print(){} ) inside the function void printUserData(const struct UserData* userData){}. Generally speaking, you cannot put a function inside a function. I chose the if statement if(intPressure != 0)|{} to be inside the void printUserData function because I wanted this if statement to use the variable int intPressure = atoi(userData->pressure); . This variable decides about whether the LED_BUILTIN is LOW or HIGH.
Maybe one way to solve this is to make int intPressure = atoi(userData->pressure); to a global variable, so that it can be easily accessed by any function, particularly the void loop() function? This way, I could also just move the If statement if(intPressure != 0)|{} to the void loop() function. If this a good way to go, how would you do that?
Also, personally, I would not name a function that I wrote 'print'. It appears to be a keyword in Arduino. At least the IDE makes it a different color and that makes me nervous.
Yes, but if someone else went to the trouble of putting it in keywords.txt it would make me nervous if my function name turned orange.
@Delta_G
Clarification of my 2nd problem:
I wanted to make the local variable tweet from function printUserData to a global variable so this local variable can be accessed by the void loop() function. I learned that this is not a good practice, making local variables to global ones:
New programmers are often tempted to use lots of global variables, because they are easy to work with, especially when many functions are involved. However, use of non-const global variables should generally be avoided altogether!
source: http://www.learncpp.com/cpp-tutorial/42-global-variables/
Back to my 2nd and last problem here:
In order to make a variable from another function available inside the void loop() function you may do the following:
I am using the data type byte to make tweet as a byte variable. Inside the printUserData function tweet will return the value also to the void loop function(), since its stored inside byte tweet. This worked for me.
source: https://www.arduino.cc/en/Reference/Byte
byte printUserData(const struct UserData* userData) {
  byte tweet = 0; // will return the value of this variable
  int print() {
    tweet = HIGH;
    tweet = LOW;
   return tweet;
  byte tweet=0;
0011:
Absolutely correct. And yet in your current code you are still doing ...
  int print() {
Can you explain why you're still doing this, when way back in your reply #6 you so clearly told us that you understood that you cannot?
Thank you for your comments. I will come back to you guys here, once I understand.
Dude, by seeing the code you have provided I can tell you that you have forgotten to start the serial communication, Serial.begin(9600);
Second mistake, you must call the function. Calling a function means to "trigger" it.
Example:
void setup(){
void loop(){
int x =0;
if( x==0){
cheesecake(); //cheesecake() calls the
//function called cheesecake
void cheesecake(){
//after calling cheesecake you come here
//here do whatever you want
