How to return the value from void function and use it inside in another function or in the void loop?
How to return the value from a void function and use it inside in another function or in the void loop?
Goal: I want the variable get the data to from another function (byte selector) to another function (byte signalpwm_1). The result will be at serial which either (1 or 2 or 3) so than I can switch-case afterwards.
Problem: the outcome is shown as available. the output is quite strange:
000 - correct
010 - wrong should've = 012
100 - wrong should've = 101
code:
#define pwm_1a 5 // signal output 1a
#define pwm_1b 6 // signal output 1b
#define joystick_1 A0 // signal analog 1
#define signalpwm_1a 7 // signal digital 1a
#define signalpwm_1b 8 // signal digital 1b
byte valsignalpwm[5];
int valsignalpwm_1a;
int valsignalpwm_1b;
int i;
byte selector(int selector_a, int selector_b){
if((selector_a == 1) && (selector_b == 0)){
valsignalpwm[i] == 1;
if((selector_a == 0) && (selector_b == 1)){
valsignalpwm[i] == 2;
else{
valsignalpwm[i] == 0;
Serial.print(valsignalpwm[1]);
return valsignalpwm[i];
byte signalpwm_1(){
valsignalpwm_1a = digitalRead(signalpwm_1a);
valsignalpwm_1b = digitalRead(signalpwm_1b);
i = 1;
delay(100);
selector(valsignalpwm_1a, valsignalpwm_1b);
void serial(){
Serial.print(valsignalpwm_1a);
Serial.println(valsignalpwm_1b);
pinMode(signalpwm_1a, INPUT);
pinMode(signalpwm_1b, INPUT);
pinMode(pwm_1a, OUTPUT);
pinMode(pwm_1b, OUTPUT);
signalpwm_1();
serial();
}Untitled
Maybe Serial.print(valsignalpwm[1]); should be Serial.print(valsignalpwm[i]);
it does not work. Should i change the data type?
if a function is defined as void will return void type of data (let's say nothing).
If you need to return a value from a function you have to define it with the type of data you want to be returned
int mySum(int a, int b) {
  int res = a + b;
  return res;
Please use code tags when posting code. It makes it more readable.
Why don't you pass the 'i' variable as a parameter to the selector function? This would be much clearer than a global with such a generic name.
This statement is not assigning the variable the value 1, it is doing a compare and throwing away the result. Same for the other similar statements in the selector() function.
The .print should be for [i] not [1].
Also, you return the value but do nothing with it, is this deliberate?
It is not yet clear to me what you want to do.
To explain it describe the functionality
there is a first function called selector
there is a second function called signalpwm_1
function selector uses two parameters
byte selector(int selector_a, int selector_b) {
depending on the two parameters the return-value shall be
1, 2 or 3
so what should happen with the return-value of your function selector?
please describe the functionality because your code does some nonsense.
if selector returns value 1 then .... .... should be ......
if selector returns value 2 then .... .... should be ......
if selector returns value 3 then .... .... should be ......
shortest way to create values 1, 2, 3 from two single bits beeing 0 or 1
is to bitshift left one bit and add the other bit
here is a democode with two - in general - useful functions that demonstrates that
void PrintFileNameDateTime() {
  Serial.println("Code running comes from file ");
  Serial.println(__FILE__);
  Serial.print("  compiled ");
  Serial.print(__DATE__);
  Serial.print(" ");
  Serial.println(__TIME__);
// easy to use non-blocking timer-function
// which becomes true after EACH Timeperiod
// suitable for continuous On/Off-"blinking"
// not suitable for one-shot-timing
boolean TimePeriodIsOver (unsigned long &expireTime, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - expireTime >= TimePeriod )
    expireTime = currentMillis; // set new expireTime
    return true;                // more time than TimePeriod) has elapsed since last time if-condition was true
  else return false;            // not expired
unsigned long MyTestTimer = 0;                   // variables MUST be of type unsigned long
// on ESP8266 and ESP32 onboard-LED is IO-pin 2
// on Arduino Uno Onboard-LEDis IO-pin 13
const byte    OnBoard_LED = 2;
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
  static unsigned long MyBlinkTimer;
  pinMode(IO_Pin, OUTPUT);
  if ( TimePeriodIsOver(MyBlinkTimer,BlinkPeriod) ) {
    digitalWrite(IO_Pin,!digitalRead(IO_Pin) );
  // make sure the baudrate in the serial-monitor
  // is adjusted to 115200 baud
  delay(200); // short wait for serial to open on computer
  Serial.println("Setup-Start");
  PrintFileNameDateTime();
int MyVarA;
int MyVarB;
int MyOutput;
  // indicates loop is running
  BlinkHeartBeatLED(OnBoard_LED,250);
  if ( TimePeriodIsOver(MyTestTimer,1000) ) {
    MyVarA = 0;
    MyVarB = 0;
    MyOutput = (MyVarB << 1) + MyVarA;
    Serial.print("A=0, B=0 Out=");
    Serial.println(MyOutput);
    MyVarA = 1;
    MyVarB = 0;
    Serial.print("A=1, B=0 Out=");
    MyVarA = 0;
    MyVarB = 1;
    Serial.print("A=0, B=1 Out=");
    MyVarA = 1;
    MyVarB = 1;
    Serial.print("A=1, B=1 Out=");
best regards Stefan
