I'm working with TFT_eSPI sketch to get a basic grasp on the TFT and touch functionalities.
This function is for the TFT rotation.
tft.setRotation(2);
But how to set the touch rotation too ?
tft.setRotation(2);
The touchScreen calls a function which returns a struct with either 3 or 2 fields. X, Y and sometimes Z (which is used for pressure). If you want to modify the rotation, you can let the X value make the Y value, or the X or Y value be the Width - X or Height - Y.
Basically you have to calculate it yourself.
the TFT rotation influences character drawing and libraries that take care of that, so the tft library needs to take care of that.
Yeah, it turned out that the variables in the header file actually works to serve this purpose:
uint16_t touchCalibration_x0 = 180, touchCalibration_x1 = 3380, touchCalibration_y0 = 380, touchCalibration_y1 = 3550;
This actually determines whether it's in portrait or landscape mode ?
touchCalibration_rotate
These determine the flip of x and y in each rotation mode:
uint8_t touchCalibration_rotate = 0, touchCalibration_invert_x = 0;
