Hello, I am a newbie in arduino.
I am using Arduino NodeMcu ESP8266 and a Arduino GY-NEO6MV2 GPS module to receive the coordinate,
but I do not know how to send it into database(PHPMyadmin).
Can anyone help me?
Thank you in Advance
Can anyone help me?
I try using this code
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <TinyGPS.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
TinyGPS gps;
SoftwareSerial ss(4,3);
IPAddress server_addr(127,x,x,x); //This is okay
char user[]="root";
char password[]="";
char INSERT_SQL[] = "INSERT INTO evento.lonlat(longitude, latitude) VALUES (flon,flat)";
char ssid[] = "Myssid";
char pass[] = "Mypassword";
WiFiClient client;
MySQL_Connection conn(&client);
MySQL_Cursor* cursor;
ss.begin(9600);
// Serial.println("Connecting to %s", ssid);
WiFi.begin(ssid,pass);
while (WiFi.status() !=WL_CONNECTED){
Serial.print(".");
Serial.print("Simple TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("by Mikal Hart");
Serial.println("\nConnected to network");
Serial.print("My IP address is: ");
Serial.print("Connecting to SQL... ");
if (conn.connect(server_addr, 80, user, password))
Serial.println("OK.");
Serial.println("FAILED.");
// create MySQL cursor object
cursor = new MySQL_Cursor(&conn);
bool newData = false;
unsigned long chars;
unsigned short sentences, failed;
// For one second we parse GPS data and report some key values
for (unsigned long start = millis(); millis() - start < 1000;)
while (ss.available())
char c = ss.read();
//Serial.write(c); // uncomment this line if you want to see the GPS data flowing
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData)
float flat, flon;
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
Serial.print("LAT=");
Serial.print(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 6);
Serial.print(" LON=");
Serial.print(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 6);
Serial.print(" SAT=");
Serial.print(gps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : gps.satellites());
Serial.print(" PREC=");
Serial.print(gps.hdop() == TinyGPS::GPS_INVALID_HDOP ? 0 : gps.hdop());
gps.stats(&chars, &sentences, &failed);
Serial.print(" CHARS=");
Serial.print(chars);
Serial.print(" SENTENCES=");
Serial.print(sentences);
Serial.print(" CSUM ERR=");
Serial.println(failed);
if (chars == 0){
Serial.println("** No characters received from GPS: check wiring **");
if (conn.connected())
cursor->execute(INSERT_SQL);
delay(5000);
but it gave this error
"Connecting to SQL... FAILED.
ERROR: Class requires connected server."
