I am tring to store data in mysql database.. From ESP8266 with GPS Neo 6M.. I am Beginner
Hey, I am tring to store data in mysql database.. From ESP8266 with GPS Neo 6M.. I am Beginner. I cant see any error every thing works fine. even get httpresponcode 200 each time cant get where is the issue please help me!!
Arduino Code
#include <TinyGPS++.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#include <SoftwareSerial.h>
TinyGPSPlus gps;
SoftwareSerial SerialGPS(4, 5);
const char* ssid = "***";
const char* password = "***";
float Latitude , Longitude;
int year , month , date, hour , minute , second, id = 1;
String DateString , TimeString , LatitudeString , LongitudeString;
const char* serverName = "http://****/lut2ms/sensor-data.php";
String apiKeyValue = "tPmAT5Ab3j7F9";
WiFiServer server(80);
  SerialGPS.begin(9600);
  Serial.print("Connecting");
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  server.begin();
  Serial.println("Server started");
  while (SerialGPS.available() > 0)
    if (gps.encode(SerialGPS.read()))
      if (gps.location.isValid())
        Latitude = gps.location.lat();
        LatitudeString = String(Latitude , 6);
        Longitude = gps.location.lng();
        LongitudeString = String(Longitude , 6);
      if (gps.date.isValid())
        DateString = "";
        date = gps.date.day();
        month = gps.date.month();
        year = gps.date.year();
        if (date < 10)
        DateString = '0';
        DateString += String(date);
        DateString += " / ";
        if (month < 10)
        DateString += '0';
        DateString += String(month);
        if (year < 10)
        DateString += '0';
        DateString += String(year);
      if (gps.time.isValid())
        TimeString = "";
        hour = gps.time.hour()+ 5; //adjust UTC
        minute = gps.time.minute();
        second = gps.time.second();
        if (hour < 10)
        TimeString = '0';
        TimeString += String(hour);
        TimeString += " : ";
        if (minute < 10)
        TimeString += '0';
        TimeString += String(minute);
        if (second < 10)
        TimeString += '0';
        TimeString += String(second);
  WiFiClient client;
  HTTPClient http;
    http.begin(client, serverName);
    http.addHeader("Content-Type", "application/x-www-form-urlencoded");
    String httpRequestData = "api_key=" + apiKeyValue + "&sensor=" + "sss" + "&location=" + LatitudeString + "&value1=" + LongitudeString + "&value2=" + DateString + "&value3=" + TimeString + "";
    int httpResponseCode = http.POST(httpRequestData);
    if (httpResponseCode>0) {
      Serial.print("HTTP Response code: ");
      Serial.println(httpResponseCode);
    else {
      Serial.print("Error code: ");
    http.end();
  delay(30000);
Php Code
<?php
include "config/config.php";
$api_key_value = "tPmAT5Ab3j7F9";
$api_key= $sensor = $location = $value1 = $value2 = $value3 = "";
if ($_SERVER["REQUEST_METHOD"] == "POST") {
    $api_key = test_input($_POST["api_key"]);
    if($api_key == $api_key_value) {
        $sensor = test_input($_POST["sensor"]);
        $location = test_input($_POST["location"]);
        $value1 = test_input($_POST["value1"]);
        $value2 = test_input($_POST["value2"]);
        $value3 = test_input($_POST["value3"]);
        $sql = "INSERT INTO SensorData (sensor, location, value1, value2, value3)
        VALUES ('" . $sensor . "', '" . $location . "', '" . $value1 . "', '" . $value2 . "', '" . $value3 . "')";
        if ($conn->query($sql) === TRUE) {
            echo "New record created successfully";
        else {
            echo "Error: " . $sql . "<br>" . $conn->error;
        $conn->close();
    else {
        echo "Wrong API Key provided.";
else {
    echo "No data posted with HTTP POST.";
function test_input($data) {
    $data = trim($data);
    $data = stripslashes($data);
    $data = htmlspecialchars($data);
    return $data;
What happens if you hit your PHP page from a browser?
Prints this line..
Can you echo the value of $_SERVER["REQUEST_METHOD"]?
Topic moved to a more suitable location onthe forum as thisdoes not seem to be related to covid.
