How to send midi notes?
Hello,
I'm a beginner in arduino's world. I'm a student who works in electronics, and i have already done some things on mbed (like arduino), or some projects in C.
I discovered arduino at the same time i get my mbed. So i ordered a arduino uno because it has a biggest communauty than mbed.
My project is : i would like to connect a simple hc sr04 to the arduino thanks to a breadboard and then i would like to play notes in MIDI depending on the distance of an object. For example, if my hand is at 30centimeters, it will play a C.
I looked for a software called LoopBe, which simulate a midi output with the usb. Then, i have tried to make a simple program but i dont know if it will work, i will receive my arduino uno tomorrow or the day after tomorrow.
My program is :
int trig = 12; //broche
int echo = 11;
long lecture_echo;
long cm;
pinMode(trig, OUTPUT);
digitalWrite(trig, LOW);
pinMode(echo, INPUT);
digitalWrite(trig, HIGH);
delayMicroseconds(10);
lecture_echo = pulseIn(echo, HIGH);
cm = lecture_echo / 58 //distance in cmeters
if(cm<=70 && cm>60)
MIDI_TX(129,60, 127) //play a C
delay(100);
else if(cm<=60 && cm>50)
MIDI_TX(129,62, 127) //play a D
delay(100);
void MIDI_TX(unsigned char MESSAGE, unsigned char DONNEE1, unsigned char DONNEE2) //fonction d'envoi du message MIDI
Serial.write(MESSAGE); //envoi de l'octet de message sur le port série
Serial.write(DONNEE1); //envoi de l'octet de donnée 1 sur le port série
Serial.write(DONNEE2); //envoi de l'octet de donnée 2 sur le port série
In the function MIDI_TX, 60 and 62 have been taken here : http://newt.phys.unsw.edu.au/jw/graphics/notes.GIF
But it seems wired that it is just like that, i guess i should write something after the function MIDI_TX (i have taken it from a website) but i don't know what... Can someone help me? Thanks in advance
I would use the MIDI tutorial: http://arduino.cc/en/Tutorial/Midi
or the MIDI library: Arduino Playground - MIDILibrary
So i read the tutorial, and so i just have to do this :
if(cm<=70 && cm>60)
noteOn(0x90, note, 0x45);
delay(100);
//Note on channel 1 (0x90), some note value (note), silent velocity (0x00):
noteOn(0x90, note, 0x00);
delay(100);
void noteOn(int cmd, int pitch, int velocity) {
Serial.write(cmd);
Serial.write(pitch);
Serial.write(velocity);
? And how can i know the hexa code for midi notes please?
Vinke60:
Google.
