Tutorial para iniciar MIDI+Arduino
Les dejo este tutorial como empezar en proyectos MIDI basados en arduino
Trata sobre el proyecto que viene de ejemplo en el IDE de arduino sobre MIDI
  MIDI note player
  This sketch shows how to use the serial transmit pin (pin 1) to send MIDI note data.
  If this circuit is connected to a MIDI synth, it will play the notes
  F#-0 (0x1E) to F#-5 (0x5A) in sequence.
  The circuit:
  - digital in 1 connected to MIDI jack pin 5
  - MIDI jack pin 2 connected to ground
  - MIDI jack pin 4 connected to +5V through 220 ohm resistor
  - Attach a MIDI cable to the jack, then to a MIDI synth, and play music.
  created 13 Jun 2006
  modified 13 Aug 2012
  by Tom Igoe
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/Midi
  // Set MIDI baud rate:
  Serial.begin(31250);
  // play notes from F#-0 (0x1E) to F#-5 (0x5A):
  for (int note = 0x1E; note < 0x5A; note ++) {
    //Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
    noteOn(0x90, note, 0x45);
    delay(100);
    //Note on channel 1 (0x90), some note value (note), silent velocity (0x00):
    noteOn(0x90, note, 0x00);
    delay(100);
// plays a MIDI note. Doesn't check to see that cmd is greater than 127, or that
// data values are less than 127:
void noteOn(int cmd, int pitch, int velocity) {
  Serial.write(cmd);
  Serial.write(pitch);
  Serial.write(velocity);
La idea es explicar los errores básicos y poder iniciar en el mundo del MIDI basado en arduno
