Hai all, i have problem with my program, i don't know how to send data from my nodemcu. i have managed to send data from arduino uno to nodemcu using serial communication but i have an ultrasonic sensor connected to nodemcu, i want it when i open the serial monitor my sensor on nodemcu and arduino is running. I've done many things but still fail
#define triggerPin1 D8
#define echoPin1 D6
#define triggerPin2 D8
#define echoPin2 D7
int led1= D1;
int ledr1= D2;
int led2= D3;
int ledr2= D4;
// millis sebagai ganti delay
unsigned long previousMillis = 0;
const long interval = 3000;
//variable array untuk data parsing
String arrData[4];
Serial.begin (9600);
pinMode(triggerPin1, OUTPUT);
pinMode(echoPin1, INPUT);
pinMode(triggerPin2, OUTPUT);
pinMode(echoPin2, INPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(ledr1, OUTPUT);
pinMode(ledr2, OUTPUT);
long duration1, jarak1;
digitalWrite(triggerPin1, LOW);
delayMicroseconds(2);
digitalWrite(triggerPin1, HIGH);
delayMicroseconds(10);
duration1 = pulseIn(echoPin1, HIGH);
jarak1 = (duration1/2) / 29.1;
Serial.print("Sensor1 :");
Serial.print(jarak1);
Serial.println("cm");
if (jarak1 <= 15) {
digitalWrite(led1, LOW);
digitalWrite(ledr1, HIGH);
} else{
digitalWrite(led1, HIGH);
digitalWrite(ledr1, LOW);
//Sensor2
long duration2, jarak2;
digitalWrite(triggerPin2, LOW);
digitalWrite(triggerPin2, HIGH);
duration2 = pulseIn(echoPin2, HIGH);
jarak2 = (duration2/2) / 29.1;
Serial.print("Sensor2 :");
Serial.print(jarak2);
if (jarak2 <= 15) {
digitalWrite(led2, LOW);
digitalWrite(ledr2, HIGH);
} else{
digitalWrite(led2, HIGH);
digitalWrite(ledr2, LOW);
// konfigurasi millis
unsigned long currentMillis = millis(); // baca waktu millis saat ini
if(currentMillis - previousMillis >= interval){
//update privousMillis
//baca data dari arduino uno
// baca data serial
String data ="";
while(Serial.available()>0){
data += char(Serial.read());
//hapus spasi data
data.trim();
if(data !=""){
//parsing data
int index = 0;
for(int i=0; i<= data.length(); i++){
char delimiter = '#';
if(data[i] != delimiter)
arrData[index] += data[i];
index++;
//pastikan data yang dikirim lengkap
if(index == 1){
//tampilkan nilai sensor
Serial.println("Sensor3 :" + arrData[0] + "cm");
Serial.println("Sensor4 :" + arrData[1] + "cm");
arrData[0] = "";
arrData[1] = "";
//minta data ke arduino uno
Serial.println("Ya");
