Hello!
How to set Fuse bits & Lock bits settings for copy protection my program or .HEX in ATmega328p by Using MiniPro Programmer. I don't want upload bootloader.
The description is in the ATMEGA328p datasheet chapter 28 Memory Programming.
The order of setting the bits is important. If you make a mess of it, you may need a high voltage parallel programmer to rescue the chip.
Your security is maintained, however, in that the contents of the flash memory will be erased before the lock bits can be reset.
