Can anyone help me how to show a bitmap on OLED display(128x64) from SD card.
I have tried the code which is below but the image is scattered.
#include <Wire.h>
#include <OzOLED.h>
#include <SD.h>
#define SIZE 128*64/8
char buf[SIZE];
File root;
File myFile;
void setup(){
if (!SD.begin(53)) {
Serial.println("Initialization Failed");
delay(3000);
return;
}else{
Serial.println("Initialization OK");
delay(3000);
myFile = SD.open("OLED.H");
OzOled.init(); //initialze Oscar OLED display
void loop(){
OzOled.clearDisplay(); // clear the screen and set start position to top left corner
if (myFile && myFile.available()) {
myFile.read(buf, SIZE);
myFile.close();
Serial.println("Replay.");
//delay(10);
OzOled.drawBitmap((const uint8_t*)buf, 0, 0, 16, 8);
OLED.H File :
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0,
0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF0,
0xF8, 0xF8, 0xFC, 0xFE, 0xFE, 0xFF, 0x3F, 0x1F, 0x0F, 0x07, 0x07, 0x03, 0x03, 0x03, 0x03, 0x01,
0x01, 0x03, 0x03, 0x03, 0x03, 0x07, 0x07, 0x0F, 0x1F, 0x3F, 0x7F, 0xFE, 0xFE, 0xFC, 0xFC, 0xF8,
0xF0, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0xE0, 0xF0, 0x10, 0x18, 0x08, 0x08, 0x08,
0x18, 0x38, 0x70, 0xE0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xF0, 0x3C, 0x0E, 0x0F, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0x0F, 0x0F, 0x3C, 0xF0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xC0, 0x83, 0x0F, 0x0F, 0x00, 0x00, 0x00, 0x00,
0x80, 0xE0, 0x78, 0x1F, 0x37, 0x38, 0xBC, 0xFC, 0xE4, 0x80, 0x00, 0x00, 0xE0, 0xF0, 0x38, 0x28,
0xB8, 0x98, 0x80, 0xC0, 0xE0, 0x30, 0x18, 0x88, 0xC8, 0xF8, 0xB8, 0x80, 0x3C, 0x3C, 0xEC, 0xF8,
0x98, 0x88, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xFE, 0x1F, 0x01, 0x00, 0x00, 0xC0, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xF8, 0xE0, 0xC0, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0xC0, 0xE0, 0xF0, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
0x01, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01,
0x01, 0x01, 0x00, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00, 0x01, 0x01,
0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xE0, 0xF0, 0xF8, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFE, 0xFE, 0x7E,
0x7E, 0xFE, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFC, 0xF0, 0xE0, 0xFF, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0x60,
0x60, 0x20, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x07, 0x0F, 0x1F, 0x3F, 0x3F, 0x7F, 0x7F,
0xFF, 0x8F, 0x07, 0x07, 0x03, 0x01, 0x01, 0x01, 0x00, 0xF0, 0xFC, 0xFC, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xF8, 0xFC, 0xFC, 0x00, 0x01, 0x01, 0x03, 0x03, 0x07, 0x0F, 0xDF, 0xFF,
0x7F, 0x7F, 0x3F, 0x3F, 0x1F, 0x0F, 0x07, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xF0, 0x7E, 0x1F, 0x07, 0x01, 0x00,
0x04, 0x06, 0x03, 0x81, 0xE0, 0x6C, 0x0C, 0x04, 0x00, 0x00, 0x80, 0xC0, 0x60, 0x20, 0x20, 0xE0,
0xE0, 0x00, 0xD0, 0xF0, 0xE0, 0x60, 0x20, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0xC0, 0xC0, 0x60, 0x20,
0x20, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x03, 0x0F, 0x3C, 0x70, 0x60, 0xC0, 0xC0, 0xC0, 0x80, 0x80, 0x83, 0x83, 0x80, 0x80, 0x80, 0x80,
0x80, 0x80, 0x80, 0x80, 0x81, 0x83, 0x83, 0x80, 0xC0, 0xC0, 0xC0, 0x60, 0x30, 0x1C, 0x0F, 0x01,
0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x04, 0x06, 0x07, 0x05, 0x04, 0x04, 0x04, 0x04, 0x04, 0x04,
0x04, 0x04, 0x00, 0x07, 0x07, 0x04, 0x06, 0x02, 0x00, 0x07, 0x07, 0x04, 0x04, 0x06, 0x07, 0x07,
0x06, 0x06, 0x07, 0x03, 0x00, 0x06, 0x07, 0x05, 0x06, 0x02, 0x80, 0x87, 0x87, 0x04, 0x84, 0xF6,
0xFF, 0x1F, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x03, 0x02, 0x02, 0x03, 0x01,
Thanks.
