Hi. I'm not native, sorry for the bad english. I'm using an NodeMCU esp32-s, and I keep getting this error when I try to connect the code. Some things are in spanish.
#include <Wire.h>
#include <Arduino.h>
#include <MQ135.h>
#include "DHT.h"
#include <WiFi.h>
#include "ThingSpeak.h"
// Configuración del LCD
LiquidCrystal_I2C lcd(0x27, 16, 2); // Dirección I2C y tamaño del LCD (16 columnas y 2 filas)
int screen = 0;
//Configuración WiFi y ThingSpeak
const char* ssid = "...";
const char* password = "...";
unsigned long channelID = ....;
const char* WriteAPIKey = "...";
WiFiClient Client;
// Temporizadores para cambios de pantalla y actualizaciones de ThingSpeak
unsigned long previousMillis = 0; // Para gestionar los cambios de pantalla
const long interval1 = 60000; // Intervalo de 1 minuto (60,000 ms)
// Pines de sensores
//#define PIN_MQ135 A0 // MQ135 Analog Input Pin
#define DHTPIN 25 // DHT Digital Input Pin
#define DHTTYPE DHT11 // DHT 11
//MQ135 mq135_sensor(PIN_MQ135);
DHT dht(DHTPIN, DHTTYPE);
// Variables para temperatura y humedad
float t = 0.0, h = 0.0, hic = 0.0;
const int PIN_R1 = 33; // LED Rojo RGB1
const int PIN_Y1 = 23; // LED Amarillo/Azul RGB1
const int PIN_G1 = 32; // LED Verde RGB1
const int PIN_R2 = 19; // LED Rojo RGB2
const int PIN_Y2 = 5; // LED Amarillo/Azul RGB2
const int PIN_G2 = 18; // LED Verde RGB2
const int freq = 500; // Frecuencia PWM ajustada a 500 Hz
const int LED_CHANNEL_R1 = 0;
const int LED_CHANNEL_Y1 = 1;
const int LED_CHANNEL_G1 = 2;
const int LED_CHANNEL_R2 = 3;
const int LED_CHANNEL_Y2 = 4;
const int LED_CHANNEL_G2 = 5;
const int resol = 8; // Resolución de 8 bits
const int buzzer = 17;
// Inicializar LEDs y buzzer
pinMode(PIN_R1, OUTPUT);
pinMode(PIN_Y1, OUTPUT);
pinMode(PIN_G1, OUTPUT);
pinMode(PIN_R2, OUTPUT);
pinMode(PIN_Y2, OUTPUT);
pinMode(PIN_G2, OUTPUT);
pinMode(buzzer, OUTPUT);
// Configurar PWM para cada canal
ledcSetup(LED_CHANNEL_R1, freq, resol);
ledcSetup(LED_CHANNEL_Y1, freq, resol);
ledcSetup(LED_CHANNEL_G1, freq, resol);
ledcSetup(LED_CHANNEL_R2, freq, resol);
ledcSetup(LED_CHANNEL_Y2, freq, resol);
ledcSetup(LED_CHANNEL_G2, freq, resol);
// Asignar los pines al canal PWM correspondiente
ledcAttachPin(PIN_R1, LED_CHANNEL_R1);
ledcAttachPin(PIN_Y1, LED_CHANNEL_Y1);
ledcAttachPin(PIN_G1, LED_CHANNEL_G1);
ledcAttachPin(PIN_R2, LED_CHANNEL_R2);
ledcAttachPin(PIN_Y2, LED_CHANNEL_Y2);
ledcAttachPin(PIN_G2, LED_CHANNEL_G2);
// Inicializar comunicación Serial
// Conexión Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Conectando a WiFi...");
Serial.print(".");
Serial.println("WiFi conectado.");
// Inicializar ThingSpeak
ThingSpeak.begin(Client);
// Inicializar sensores
dht.begin();
// Inicializar LCD
lcd.begin(); // Usar lcd.init() en lugar de lcd.begin() para algunas librerías
lcd.setCursor(0, 0);
lcd.print("Monitoreo");
lcd.setCursor(0, 1);
lcd.print("Ambiental");
delay(2000);
// La lectura de la temperatura o humedad toma aproximadamente 250 milisegundos.
// Las lecturas pueden demorarse 2 segundos debido a la lentitud del sensor.
h = dht.readHumidity(); // Humedad
t = dht.readTemperature(); // Temperatura en Celsius (default)
hic = dht.computeHeatIndex(t, h, false); // Computa la sensación térmica en Celsius (isFahreheit = false)
// Verificar si hay errores en la lectura de los sensores
if (isnan(h) || isnan(t)) {
Serial.println(F("Falla en el sensor DHT11!"));
lcd.clear();
lcd.print("Falla");
lcd.print("Sensor DHT11");
return; // Salir del loop para evitar ejecutar el resto del código
// Leer el sensor MQ135
//float mq135_value = mq135_sensor.getPPM(); // Obtener el valor de CO2 en PPM
// Nota: La función getPPM() puede variar según la librería MQ135 que estés usando
// Gestión de la pantalla LCD cada minuto
if (currentMillis - previousMillis >= interval1) {
previousMillis = currentMillis; // Actualiza el temporizador
screen++; // Pasa a la siguiente pantalla
// Volver al principio cuando se muestran todas las pantallas
if (screen > 3) { // Aumenté a 3 para incluir la calidad del aire
screen = 0;
ThingSpeak.setField(1, t);
ThingSpeak.setField(2, h);
ThingSpeak.setField(3, hic);
//ThingSpeak.setField(4, mq135_value);
ThingSpeak.writeFields(channelID, WriteAPIKey);
// Control de LEDs y Buzzer basado en temperatura y sensación térmica
if (t > 38 || hic > 45) { // Valores críticos
ledcWrite(LED_CHANNEL_R1, 255); // Valor PWM máximo (8 bits = 255)
ledcWrite(LED_CHANNEL_Y1, 0); // Apagar el LED Amarillo/Azul
ledcWrite(LED_CHANNEL_G1, 0); // Apagar el LED Verde
digitalWrite(buzzer, HIGH);
delay(5000); // Mantener encendido 1 segundo
else if (t > 26 || hic > 40) { // Valores anómalos
ledcWrite(PIN_R1, 255);
ledcWrite(PIN_Y1, 0); // Encender LED Amarillo con brillo máximo
ledcWrite(PIN_G1, 255);
digitalWrite(buzzer, LOW); // Apagar buzzer
else { // Valores normales
ledcWrite(PIN_R1, 0);
ledcWrite(PIN_G1, 255); // Encender LED Verde con brillo máximo
/* Control de LEDs basado en calidad del aire (MQ135)
if (mq135_value > 1000) { // Calidad del aire peligrosa
ledcWrite(LED_CHANNEL_R2, 255);
ledcWrite(LED_CHANNEL_Y2, 0);
ledcWrite(LED_CHANNEL_G2, 0);
} else if (mq135_value > 700) { // Calidad del aire deficiente
ledcWrite(LED_CHANNEL_R2, 0);
ledcWrite(LED_CHANNEL_Y2, 255);
} else { // Calidad del aire buena
ledcWrite(LED_CHANNEL_G2, 255);
// Mostrar información en el LCD según la pantalla actual
lcd.clear();
switch (screen) {
case 0:
// Mostrar temperatura
lcd.print("Temperatura:");
lcd.print(t);
lcd.print("°C");
case 1:
// Mostrar humedad
lcd.print("Humedad:");
lcd.print(h);
lcd.print(" %");
case 2:
// Mostrar sensación térmica
lcd.print("Sens Termica:");
lcd.print(hic);
lcd.print("°C");
/*case 3:
// Mostrar calidad del aire (MQ135)
lcd.print("Calidad Aire:");
lcd.print(mq135_value);
lcd.print(" PPM");
// Imprimir valores en el Serial Monitor
Serial.print(F("Humedad: "));
Serial.print(h);
Serial.print(F("% Temperatura: "));
Serial.print(t);
Serial.print(F("°C Sens. Termica: "));
Serial.print(hic);
Serial.print(F("°C Calidad Aire: "));
//Serial.print(mq135_value);
//Serial.println(F(" PPM"));
ThingSpeak.setField(2,h);
ThingSpeak.setField(3,hic);
// Pequeño retardo para estabilidad
delay(100); // 100 ms para evitar lecturas demasiado rápidas
