how to stop led ON after 5 times
hi there, i'm beginner to Arduino,
i need some help to solve my problem.
how to stop led ON after 5 times?
this is my code
pinMode(18, OUTPUT);
digitalWrite(18, HIGH); // turn the LED on
delay(1000); // wait for a second
digitalWrite(18, LOW); // turn the LED off
First welcome to the forum. Second before any one mentions it they would like you to use code tags. What is a code tag? At the top of you screen you will see </> This is a code tag. the easiest way to use it is copy your sketch click on the code tag Paste you sketch between the <> symbols. It is that simple.
By the way I do not see a counting routine in your code to count to 5.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html
then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What model arduino are you using?
Thanks .. Tom... :slight_smile:
Move it into a for:loop in setup():
byte count ;
 for (count = 0; count <5; count = count +1){
