I want the led only to blink for 500mili sec and turn off till the next count
int FWGear = 3; //Foward button
int BWGear = 4; //Backward button
int NGear = 5;  //Netural button
int RGear = 6; //Reverse button
//variables
int GearCount = 1;
int FWGearNew;
int FWGearOld = 1;
int BWGearNew;
int BWGearOld = 1;
int NGearNew;
int NGearOld = 1;
int RGearNew;
int RGearOld = 1;
// led pins
int NLed = 7;
int G1Led = 8;
int G2Led = 9;
int G3Led = 10;
int G4Led = 11;
int G5Led = 12;
int G6Led = 14;
int G7Led = 15;
int G8Led = 16;
void setup ()
  pinMode(FWGear, INPUT_PULLUP); //Foward button
  pinMode(BWGear, INPUT_PULLUP); //Backward button
  pinMode(NGear, INPUT_PULLUP); //Netural button
  pinMode(RGear, INPUT_PULLUP); //Reverse button
  pinMode(NLed, OUTPUT);
  pinMode(G1Led, OUTPUT);
  pinMode(G2Led, OUTPUT);
  pinMode(G3Led, OUTPUT);
  pinMode(G4Led, OUTPUT);
  pinMode(G5Led, OUTPUT);
  pinMode(G6Led, OUTPUT);
  pinMode(G7Led, OUTPUT);
  pinMode(G8Led, OUTPUT);
  FWbutton();
  BWbutton();
  Nbutton();
  Rbutton();
  Reverse();
  Neutral();
  First();
  Second();
  Third();
  Forth();
  Fifth();
  Sixth();
  Seventh();
// Foward Gear Button Count
void FWbutton()
  FWGearNew=digitalRead(FWGear);
  delay(100);
   if(FWGearOld==1 && FWGearNew==0 && GearCount <8)
    GearCount = GearCount += 1;
   FWGearOld=FWGearNew;
// Backward Gear Button Count
void BWbutton()
  BWGearNew=digitalRead(BWGear);
  delay(100);
   if(BWGearOld==1 && BWGearNew==0 && GearCount >1)
    GearCount = GearCount -= 1;
   BWGearOld=BWGearNew;
void Nbutton()
  NGearNew=digitalRead(NGear);
  delay(100);
   if(NGearOld==1 && NGearNew==0 && GearCount >-1)
    GearCount = 1;
   NGearOld=NGearNew;
void Rbutton()
  RGearNew=digitalRead(RGear);
  delay(100);
   if(RGearOld==1 && RGearNew==0 && GearCount >0)
    GearCount = 0;
   RGearOld=RGearNew;
// Led Funtions Based On Button Count
**void Reverse()**
**  if(GearCount==0)**
**    digitalWrite(NLed, HIGH);**
**  else**
**    digitalWrite(NLed, LOW);**
**void Neutral()**
**  if(GearCount==1)**
**    digitalWrite(G1Led, HIGH);**
**  else**
**    digitalWrite(G1Led, LOW);**
void First()
  if(GearCount==2   )
    digitalWrite(G2Led, HIGH);
    digitalWrite(G2Led, LOW);
void Second()
  if(GearCount==3)
    digitalWrite(G3Led, HIGH);
    digitalWrite(G3Led, LOW);
void Third()
  if(GearCount==4)
    digitalWrite(G4Led, HIGH);
    digitalWrite(G4Led, LOW);
void Forth()
  if(GearCount==5)
    digitalWrite(G5Led, HIGH);
    digitalWrite(G5Led, LOW);
void Fifth()
  if(GearCount==6)
    digitalWrite(G6Led, HIGH);
    digitalWrite(G6Led, LOW);
void Sixth()
  if(GearCount==7)
    digitalWrite(G7Led, HIGH);
    digitalWrite(G7Led, LOW);
void Seventh()
  if(GearCount==8)
    digitalWrite(G8Led, HIGH);
    digitalWrite(G8Led, LOW);
Hello too thanks for saying hello to everyone :slight_smile:
A lot of people want some stuff here. But also most of them provide more details and ask kindly for a support
can you help me with this
  • Tell us about your experience in hardware and software ?
  • Always show us a good schematic of your proposed circuit.
    Show us good images of your ‘actual’ wiring.
    Give links to components.
  • Show us your code preamble laying out the design ?
  • What are all the ************* about ?
2 buttons to shift up and down from zero to seven
counts from 0 - 7 up and down with buttons
for button counts I have set leds
when button count is 1, its given led starts to blink continuously, I need only to blink once
  • What are the colours on the LED series resistors ? O/O/BK
Orange Orange Brown Gold,
you can see the led is one,
i need it to turn off after 500 mili secs
  • When exactly is the LED(s) supposed to come ON ?
Available from the IDE library manager.
Try this:
void First()
  static bool blinked = false;
  if(GearCount==2)
    if (!blinked)
      blinked = true;
    blinked = false;
the program is for a gear box.
total 4 buttons
9 gears , reverse , netrual and 1 - 7
two buttons to shift up and down
one for netrual gear
one for reverse gear
just like sequential shifter
gears are indicated buy leds..
there is a solanice for each gear in gear box,
i m going to give led wire line to turn on the solanides
so i dont need led wire line to continuesly turn on,
only 500 mili sec power is enough to turn on the solanide.
so when i shift a gear, led for that gear is turning on,
but i need to stop it after 500 mili sec
  • Tell us what you think this does ?
example
if gear count is 1, when i press the FWGear button (Shift up) gear count will be 2
adding one by one
Maybe you meant:
GearCount = GearCount + 1;
Thank mate,
This code worked................ :heart_eyes:
yes
  • Had some spare time, try this version.
  • See if you can prevent going to Reverse if you are in gear ?
//                               B a s i c   S k e l e t o n   S k e t c h
//  URL
//  Version    YY/MM/DD    Comments
//  1.00       23/01/14    Running code
//  Notes:
#define LEDon              HIGH   //PIN---[220R]---A[LED]K---GND
#define LEDoff             LOW
#define PRESSED            LOW    //+5V---[Internal 50k]---PIN---[Switch]---GND
#define RELEASED           HIGH
#define CLOSED             LOW    //+5V---[Internal 50k]---PIN---[Switch]---GND
#define OPENED             HIGH
#define ENABLED            true
#define DISABLED           false
#define MAXIMUM            180
#define MINIMUM            0
#define RELAYon            LOW
#define RELAYoff           HIGH
#define ONE_SECOND   1000ul              //milliseconds
#define ONE_MINUTE   (ONE_SECOND * 60ul) //60 seconds in one minute
#define ONE_HOUR     (ONE_MINUTE * 60ul) //60 minutes in one hour
#define ONE_DAY      (ONE_HOUR * 24ul)   //24 hours in one day
//                                   c l a s s   m a k e T I M E R
  makeTIMER toggleLED =
     //.TimerType, .Interval, .TimerFlag, .Restart, .SpeedAdjustPin
     MILLIS/MICROS, 500ul, ENABLED/DISABLED, YES/NO, A0-A5
     //.SpeedAdjustPin defaults to 0 i.e. no speed adjustment is used
     //if .SpeedAdjustPin = A0-A5, a potentiometer on this pin adjusts the TIMER's speed (for diagnostics)
     //class static flag "makeTIMER::normalFlag" can be used to ENABLE/DISABLE adjustable TIMER speed,
     //ENABLE = normal speed, DISABLED = potentiometer controls TIMER speed
TIMER functions we can access:
  toggleLED.checkTIMER();
  toggleLED.enableRestartTIMER();
  toggleLED.restartTIMER()
  toggleLED.disableTIMER();
  toggleLED.expireTimer();
  toggleLED.setInterval(100ul);
Static variable access
  makeTIMER::normalFlag = ENABLED/DISABLED  //defaults to DISABLED at power up time i.e. variable speed is allowed
//                          millis() / micros()   B a s e d   T I M E R S
//These TIMER objects are non-blocking
class makeTIMER
#define MILLIS             0
#define MICROS             1
#define YES                true
#define NO                 false
#define STILLtiming        0
#define EXPIRED            1
#define TIMERdisabled      2
  private:
  public:
    static bool              s_normalFlag;    //when ENABLED, adjustable TIMERs run at normal speed
    unsigned long            Time;            //when the TIMER started
    //these "members" are needed to define a TIMER
    byte                     TimerType;       //what kind of TIMER is this? MILLIS/MICROS
    unsigned long            Interval;        //delay time which we are looking for
    bool                     TimerFlag;       //is the TIMER enabled ? ENABLED/DISABLED
    bool                     Restart;         //do we restart this TIMER   ? YES/NO
    byte                     SpeedAdjustPin;  //a potentiometer on this pin, A0-A5, adjusts TIMER speed
    //constructor with no parameters
    makeTIMER()
      TimerType = MILLIS;
      Interval = 1000ul;
      TimerFlag = ENABLED;
      Restart = YES;
      SpeedAdjustPin = 0;
      Time = 0;
    //constructor with parameters
    makeTIMER(byte _TimerType, unsigned long _Interval,
              bool _TimerFlag, bool _Restart, byte _SpeedAdjustPin = 0)
      TimerType = _TimerType;
      Interval = _Interval;
      TimerFlag = _TimerFlag;
      Restart = _Restart;
      SpeedAdjustPin = _SpeedAdjustPin;
      Time = 0;
    //condition returned: STILLtiming (0), EXPIRED (1) or TIMERdisabled (2)
    //function to check the state of our TIMER        ex: if(myTimer.checkTIMER() == EXPIRED);
    byte checkTIMER()
      //is this TIMER enabled ?
      if (TimerFlag == ENABLED)
        //is this an adjustable TIMER OR is the "normalSpeed" switch closed ?
        if (SpeedAdjustPin == 0 || s_normalFlag == ENABLED)
          //this TIMER "is not" speed adjustable,
          //has this TIMER expired ?
          if (getTime() - Time >= Interval)
            //should this TIMER restart again?
            if (Restart == YES)
              //restart this TIMER
              Time = getTime();
            //this TIMER has expired
            return EXPIRED;
        //this TIMER is speed adjustable
          //for diagnostics, we use a potentiometer to adjust TIMER speed,
          if (getTime() - Time >= Interval / adjustInterval())
            if (Restart == YES)
              Time = getTime();
            return EXPIRED;
        return STILLtiming;
      } //END of   if (TimerFlag == ENABLED)
        //this TIMER is disabled
        return TIMERdisabled;
    } //END of   checkTime()
    //function to enable and restart this TIMER       ex: myTimer.enableRestartTIMER();
    void enableRestartTIMER()
      Time = getTime();
    } //END of   enableRestartTIMER()
    //function to disable this TIMER                  ex: myTimer.disableTIMER();
    void disableTIMER()
      TimerFlag = DISABLED;
    } //END of    disableTIMER()
    //function to restart this TIMER                  ex: myTimer.restartTIMER();
    void restartTIMER()
      Time = getTime();
    } //END of    restartTIMER()
    //function to force this TIMER to expire          ex: myTimer.expireTimer();
    void expireTimer()
      //force this TIMER to expire
      Time = getTime() - Interval;
    } //END of   expireTimer()
    //function to set the Interval for this TIMER     ex: myTimer.setInterval(100);
    void setInterval(unsigned long value)
      //set the Interval
      Interval = value;
    } //END of   setInterval()
    //function to return the current time
    unsigned long getTime()
      //return the time             i.e. millis() or micros()
      if (TimerType == MILLIS)
        return millis();
        return micros();
    } //END of   getTime()
    //for diagnostics, a potentiometer on an analog pin is used to adjust TIMER speed, thanks alto777
    unsigned int adjustInterval()
      unsigned int Speed = analogRead(SpeedAdjustPin);
      //using integer math to save on memory
      Speed = 1 + (Speed * 14) / 1023;  //Speed will have a range from 1 to 15
      return Speed;
    } //END of   adjustInterval()
}; //END of   class makeTIMER
//initialize the static "s_normalFlag" variable,
bool makeTIMER::s_normalFlag = DISABLED;
//                                T I M E R   D e f i n i t i o n s
//example: uses default library values
//    MILLIS,    1000ul,    ENABLED,      YES,       0
//makeTIMER testTIMER{};
makeTIMER heartbeatTIMER =
  //.TimerType, .Interval, .TimerFlag, .Restart, .SpeedAdjustPin (A5 is the potentiometer pin)
  MILLIS, 500ul, ENABLED, YES, 0
//========================  (5ms * s_filter) i.e. 5ms * 10 = 50ms for checking a valid switch operation
makeTIMER switchesTIMER =
  MILLIS, 5ul, ENABLED, YES, 0
makeTIMER commonTIMER =
  MILLIS, 500ul, DISABLED, NO, 0
//                                  c l a s s    m a k e I n p u t
//a class to define "Input" objects, switches or sensors
class makeInput
#define NOTvalidated       0
#define VALIDATED          1
#define NOchange           2
  private:
  public:
    static byte s_filter;
    //say the above validating "s_filter" variable is set to 10
    //if we scan "inputs" every 5ms
    //i.e. we sample our inputs every 5ms looking for a change in state.
    //5ms * 10 = 50ms is needed to validate a switch change in state.
    //i.e. a switch change in state is valid "only after" 10 identical changes are detected.
    //This technique is used to filter out EMI (spikes), noise, etc.
    //i.e. we ignore switch changes in state that are less than 50ms.
    unsigned long switchTime;       //the time the switch was closed
    byte counter;                   //a counter used for validating a switch change in state
    //these "members" are needed to define an "Input"
    byte pin;                       //the digital input pin number
    byte lastState;                 //the state the input was last in
    makeInput(byte _pin, byte _lastState)
      pin = _pin;
      lastState = _lastState;
      switchTime = 0;
      counter = 0;
      pinMode(pin, INPUT_PULLUP);
    //condition returned: NOTvalidated (0), VALIDATED (1) or NOchange (2)
    //check to see if the input object has had a valid state change
    byte validChange()
      byte currentState = digitalRead(pin);
      //has there been an input change in state ?
      if (lastState != currentState)
        //we have had another similar change in state
        counter++;
        //is the "change in state" stable ?
        if (counter >= s_filter)
          //an input change has been validated
          //get ready for the next scanning sequence
          counter = 0;
          //update to this new state
          lastState = currentState;
          if (currentState == CLOSED)
            //capture the time when the switch closed
            switchTime = millis();
          return VALIDATED;
        return NOTvalidated;
      //there has not been an input change in state
      counter = 0;
      return NOchange;
    } //END of   validChange()
}; //END of   class makeInput
//a change in state is confirmed/validated when 10 identical state changes in a row is seen
byte makeInput::s_filter = 10;
//                              G P I O s   A n d   V a r i a b l e s
//Analogs
//INPUTS
//============                  GPIO 3
makeInput FWGear =
  //.pin, .lastState
  3, OPENED
//============                  GPIO 4
makeInput BWGear =
  //.pin, .lastState
  4, OPENED
//============                  GPIO 5
makeInput NGear =
  //.pin, .lastState
  5, OPENED
//============                  GPIO 6
makeInput RGear =
  //.pin, .lastState
  6, OPENED
//OUTPUTS
// led pins
const byte NLed                   = 7;
const byte G1Led                  = 8;
const byte G2Led                  = 9;
const byte G3Led                  = 10;
const byte G4Led                  = 11;
const byte G5Led                  = 12;
const byte heartbeatLED           = 13;
const byte G6Led                  = 14;
const byte G7Led                  = 15;
const byte G8Led                  = 16;
const byte myOutputs[]            = {7, 8, 9, 10, 11, 12, 13, 14, 15, 16};
//VARIABLES
const unsigned long shortPushTime = 500ul;
const unsigned long longPushTime  = 2000ul;
int GearCount                     = 0;
//the LEDs we will control
enum GEAR : byte
  Reverse, Neutral, First, Second, Third, Fourth, Fifth, Sixth, Seventh
//                                           s e t u p ( )
  //initialize outputs
  for (byte x = 0; x < sizeof(myOutputs); x++)
    digitalWrite(myOutputs[x], LEDoff);
    pinMode(myOutputs[x], OUTPUT);
} //END of   setup()
//                                            l o o p ( )
  //========================================================================  T I M E R  heartbeatLED
  //condition returned: STILLtiming, EXPIRED or TIMERdisabled
  //is it time to toggle the heartbeat LED ?
  if (heartbeatTIMER.checkTIMER() == EXPIRED)
    //toggle the heartbeat LED
    digitalWrite(heartbeatLED, digitalRead(heartbeatLED) == HIGH ? LOW : HIGH);
  //========================================================================  T I M E R  switches
  //is it time to check our switches ?
  if (switchesTIMER.checkTIMER() == EXPIRED)
    checkSwitches();
  //========================================================================  T I M E R  common
  if (commonTIMER.checkTIMER() == EXPIRED)
    //we are now finished with this TIMER
    commonTIMER.disableTIMER();
    //turn OFF the LEDS
    for (byte x = 0; x < sizeof(myOutputs) ; x++)
  //       Other non blocking code goes here
} //END of   loop()
//                                   c h e c k S w i t c h e s ( )
//we have access to:
//object.validChange()    - checks to see if there was a valid state change
//object.pin              - input hardware pin number
//object.lastState        - the state the input was/is in
//object.switchTime       - unsigned long variable where we can save millis()
void checkSwitches()
  //are we currently Timing ?
  if (commonTIMER.checkTIMER() == TIMERdisabled)
    //========================================================================  FWGear
    //was there a valid input change ?
    if (FWGear.validChange() == VALIDATED)
      //was this switch closed ?
      if (FWGear.lastState == CLOSED && GearCount < 8)
        handleLEDs();
    } //END of FWGear
    //========================================================================  BWGear
    if (BWGear.validChange() == VALIDATED)
      if (BWGear.lastState == CLOSED && GearCount > 1)
        GearCount = GearCount - 1;
        handleLEDs();
    } //END of BWGear
    //========================================================================  NGear
    if (NGear.validChange() == VALIDATED)
      if (NGear.lastState == CLOSED && GearCount > -1)
        GearCount = 1;
        handleLEDs();
    } //END of BWGear
    //========================================================================  RGear
    if (RGear.validChange() == VALIDATED)
      if (RGear.lastState == CLOSED && GearCount > 0)
        GearCount = 0;
        handleLEDs();
    } //END of RGear
  } //END of   if (commonTIMER.checkTIMER() == TIMERdisabled)
} //END of   checkSwitches()
//                                      h a n d l e L E D s ( )
//Reverse, Neutral, First, Second, Third, Fourth, Fifth, Sixth, Seventh
void handleLEDs()
  switch (GearCount)
    case Reverse:
        digitalWrite(NLed, LEDon);
        commonTIMER.setInterval(500ul);
        commonTIMER.enableRestartTIMER();
    case Neutral:
        digitalWrite(G1Led, LEDon);
    case First:
        digitalWrite(G2Led, LEDon);
    case Second:
        digitalWrite(G3Led, LEDon);
    case Third:
        digitalWrite(G4Led, LEDon);
    case Fourth:
        digitalWrite(G5Led, LEDon);
    case Fifth:
        digitalWrite(G6Led, LEDon);
    case Sixth:
        digitalWrite(G7Led, LEDon);
    case Seventh:
        digitalWrite(G8Led, LEDon);
  } //END switch/case
} //END of  handleLEDs()
  • Those LEDs are very bright, are you 100% sure those resistors are not 33 ohms ?
