Hello
i want to make automatization door who can close and open according to the height read by the sensor HC-SR04. the door move by motor DC. take a look my schematic instrument in attachment.
this is my code
const int TrigPin = 2;
const int EchoPin = 3;
const int numReadings = 10;
const int Relay1 = 11;
const int Relay2 = 12;
const int Relay3 = 13;
const int EN1 = 9;
const int DC1 = 8;
const int DC2 = 7;
const int EN2 = 6;
const int DC3 = 5;
const int DC4 = 4;
long Duration = 0;
int readings[numReadings];
int index = 0;
int total = 0;
long average = 0.0;
Serial.begin (9600);
pinMode(TrigPin, OUTPUT);
pinMode(EchoPin, INPUT);
pinMode(Relay1,OUTPUT);
pinMode(Relay2,OUTPUT);
pinMode(Relay3,OUTPUT);
pinMode(EN1,OUTPUT);
pinMode(DC1,OUTPUT);
pinMode(DC2,OUTPUT);
pinMode(EN2,OUTPUT);
pinMode(DC3,OUTPUT);
pinMode(DC4,OUTPUT);
for (int thisReading = 0; thisReading < numReadings; thisReading++) //28
readings[thisReading] = 0;
digitalWrite(TrigPin, HIGH);
delayMicroseconds(10);
digitalWrite(TrigPin, LOW);
Duration = pulseIn(EchoPin, HIGH);
long Distance = (Duration*0.034)/2;
total = total - readings[index];
readings[index] = Distance;
total = total + readings[index];
index = index +1;
if (index >= numReadings)
index = 0;
long average = (total / numReadings);
int tinggiair = 17 - average;
Serial.println(tinggiair);
if(tinggiair<7)
digitalWrite(Relay1,HIGH);
digitalWrite(Relay2,LOW);
digitalWrite(Relay3,HIGH);
analogWrite(EN1,255);
analogWrite(EN2,255);
digitalWrite(DC1,HIGH);
digitalWrite(DC2,LOW);
digitalWrite(DC3,HIGH);
digitalWrite(DC4,HIGH);
delay(3000);
digitalWrite(DC2,HIGH);
else if (tinggiair>7)
digitalWrite(Relay2,HIGH);
digitalWrite(Relay3,LOW);
digitalWrite(DC1,LOW);
digitalWrite(DC4,LOW);
delay(3000);
else if (tinggiair=7)
digitalWrite(Relay1,LOW);
digitalWrite(DC3,LOW);
delay(3000);
the problem is, when sensor detected the height is below 7cm, motor DC active for 2 second to open the door. but after 2 second motor DC stop just about split of second, after that motor DC move again for 2 second, and it will repeat until sensor detected the height is above 7cm.
program that i need is, when sensor detected the height is below 7cm, motor DC will active for 2 second and after that it will stop until sensor detected the height is above 7cm.
can anybody help me to fix my probelm?
