ghoond
April 20, 2022, 8:36am
1
Hello everyone,
Im currently trying to read sensor data for a few seconds using millis and then store it to array, but it seems didnt work. On the serial it just keeps reading. Im using arduino uno and DFRobot TDS sensor for a reference
#define TdsSensorPin A1
#define VREF 5
#define SCOUNT 30
int analogBuffer[SCOUNT];
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0,copyIndex = 0;
float averageVoltage = 0,tdsValue = 0,temperature = 25;
byte arrayTDS[30];
byte valueTDS;
unsigned long currentMillis;
unsigned long startMillis;
long interval = 5000;
int timeX = 0;
pinMode(TdsSensorPin,INPUT);
startMillis = millis();
Serial.print("Time internal of readings : ");
Serial.print(interval);
Serial.println(" milliseconds");
static unsigned long analogSampleTimepoint = millis();
if(millis()-analogSampleTimepoint > 40U)
analogBuffer[analogBufferIndex] = analogRead(A1);
analogBufferIndex++;
if(analogBufferIndex == SCOUNT)
analogBufferIndex = 0;
static unsigned long printTimepoint = millis();
if(millis()-printTimepoint > 2000U)
for(copyIndex=0;copyIndex<SCOUNT;copyIndex++)
analogBufferTemp[copyIndex]= analogBuffer[copyIndex];
averageVoltage = getMedianNum(analogBufferTemp,SCOUNT) * (float)VREF / 1024.0;
float compensationCoefficient=1.0+0.02*(temperature-25.0);
float compensationVolatge=averageVoltage/compensationCoefficient;
tdsValue=(133.42*compensationVolatge*compensationVolatge*compensationVolatge
- 255.86*compensationVolatge*compensationVolatge + 857.39*compensationVolatge)*0.5;
Serial.print("TDS Value:");
Serial.println(tdsValue,0);
currentMillis = millis();
if (currentMillis - startMillis >= interval){
arrayTDS[valueTDS] = tdsValue;
valueTDS++;
Serial.print("Hasil Tangkapan Sensor : ");
Serial.print(arrayTDS);
int getMedianNum(int bArray[], int iFilterLen)
int bTab[iFilterLen];
for (byte i = 0; i<iFilterLen; i++)
bTab[i] = bArray[i];
int i, j, bTemp;
for (j = 0; j < iFilterLen - 1; j++)
for (i = 0; i < iFilterLen - j - 1; i++)
if (bTab[i] > bTab[i + 1])
bTemp = bTab[i];
bTab[i] = bTab[i + 1];
bTab[i + 1] = bTemp;
if ((iFilterLen & 1) > 0)
bTemp = bTab[(iFilterLen - 1) / 2];
bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
horace
April 20, 2022, 8:48am
2
this error report is a bit vauge! is anything printed to the serial monitor?
as an initial test put some print statements in the first loop to check values such as analogBufferIndex, etc have the values you expect
Your sketch does not get compiled. In addition to the the absence of the declaration of valueTDS variable, there is also a lack of { balancing.
kolaha
April 20, 2022, 1:25pm
4
what do you want to do with generated array?
kolaha
April 20, 2022, 1:28pm
5
#define VREF 5
#define SCOUNT 30
int analogBufferIndex = 0, copyIndex = 0;
float averageVoltage = 0.0, tdsValue = 0.0, temperature = 25.0;
unsigned long arrayTDS[30];
byte valueTDSbyte=0;
unsigned long interval = 5000;
int timeX = 0;
void setup(){
pinMode(TdsSensorPin, INPUT);
void loop(){
if (millis() - analogSampleTimepoint > 40UL) {
if (analogBufferIndex == SCOUNT) analogBufferIndex = 0;
if (millis() - printTimepoint > 2000UL) {
for (copyIndex = 0; copyIndex < SCOUNT; copyIndex++)
analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
averageVoltage = getMedianNum(analogBufferTemp, SCOUNT) * (float)VREF / 1024.0;
float compensationCoefficient = 1.0 + 0.02 * (temperature - 25.0);
float compensationVolatge = averageVoltage / compensationCoefficient;
tdsValue = (133.42 * compensationVolatge * compensationVolatge * compensationVolatge
- 255.86 * compensationVolatge * compensationVolatge + 857.39 * compensationVolatge) * 0.5;
Serial.println(tdsValue, 0);
if ( millis()- startMillis >= interval) {
arrayTDS[valueTDSbyte] = (uint32_t)tdsValue;
valueTDSbyte++;
if(valueTDSbyte==30)valueTDSbyte=0;
for (byte i = 0; i < 30; i++)Serial.println(arrayTDS[i]);
int getMedianNum(int bArray[], int iFilterLen){
for (byte i = 0; i < iFilterLen; i++) bTab[i] = bArray[i];
int i, j, bTemp;
for (j = 0; j < iFilterLen - 1; j++) {
for (i = 0; i < iFilterLen - j - 1; i++) {
bTemp = bTab[i];
if ((iFilterLen & 1) > 0) bTemp = bTab[(iFilterLen - 1) / 2];
else bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
return bTemp;
ghoond
April 22, 2022, 3:12pm
6
Well i also going to calculate the average of the array data
kolaha
April 22, 2022, 3:30pm
7
which array, where you want to place the result?
ghoond
April 23, 2022, 1:37am
8
The arrayTDS one, the tds sensor is one of my sensors that im working on my project for my hydroponic doping system, at first the sensor read for a few seconds, then calculate the average, compare it with source data to see if it less or not, so the result will be stored first then compare it with source data that stored in another array. There's a lot of array in my project
kolaha
April 23, 2022, 7:38am
9
#define VREF 5
#define SCOUNT 30
float averageVoltage = 0.0, temperature = 25.0;
byte TDSindex = 0;
const unsigned long interval = 5000;
if (analogBufferIndex == SCOUNT) {
Serial.println("analogBuffer is full");
uint32_t TDSvalue = CalcS();
Serial.println(TDSvalue);
arrayTDS[TDSindex] = TDSvalue;
TDSindex++;
if (TDSindex == SCOUNT) {
TDSindex = 0;
static unsigned long Result = 0;
Serial.println("Hasil Tangkapan Sensor : ");
for (byte i = 0; i < SCOUNT; i++) {
Result += arrayTDS[i];
Result /= SCOUNT ;
Serial.print("Average : "); Serial.println(Result);
uint32_t CalcS() {
return (uint32_t)((133.42 * compensationVolatge * compensationVolatge * compensationVolatge
- 255.86 * compensationVolatge * compensationVolatge + 857.39 * compensationVolatge) * 0.5);
int getMedianNum(int bArray[], int iFilterLen) {
int i, j, bTemp;
bTemp = bTab[i];
return bTemp;
Hello ghoond
Take some time and check the handling of the variables for the timers.
Дайте миру шанс!
system
Closed
October 20, 2022, 8:31am
11
