How to Transmit and Receive 2 Data using LoRa Ra-02 SX1278
Hello everyone!!!!
I want to transmit 2 analog data using LoRa but I am getting this values:
Received packet 'Left: 408
Right: 947
Received packet 'Left: 428
Right: 947
Right: 948
Right: 946
Right: 947
HERE ARE MY CODES
//TRANSMITTER
#include <LoRa.h>
#include <SPI.h>
#define ss 5
#define rst 14
#define dio0 2
const int joyLpin = 34;     // left joystick
const int joyRpin = 35;     // right joystick
  while (!Serial);
  Serial.println("LoRa Sender");
  LoRa.setPins(ss, rst, dio0);    //setup LoRa transceiver module
  while (!LoRa.begin(433E6))     //433E6 - Asia, 866E6 - Europe, 915E6 - North America
    Serial.println(".");
  LoRa.setSyncWord(0xA5);
  Serial.println("LoRa Initializing OK!");
  int joyL = map(analogRead(joyLpin),0,1024,0,255);
  int joyR = map(analogRead(joyRpin),0,1024,0,255);
  Serial.println("Sending packet: ");
  LoRa.beginPacket();
  LoRa.print(joyL);
  LoRa.print(joyR);
  LoRa.endPacket();
  delay(50);
//RECEIVER
#include <LoRa.h>
#include <SPI.h>
#define ss 5
#define rst 14
#define dio0 2
int joyL;
int joyR;
String inStringL = "";
String inStringR = "";
  while (!Serial);
  Serial.println("LoRa Receiver");
  int packetSize = LoRa.parsePacket();    // try to parse packet
  if (packetSize)
    Serial.print("Received packet '");
    while (LoRa.available())              // read packet
      int inCharL = LoRa.read();
      inStringL += (char)inCharL;
      joyL = inStringL.toInt();
      int inCharR = LoRa.read();
      inStringR += (char)inCharR;
      joyR = inStringR.toInt();
    inStringL = "";
    inStringR = "";
    LoRa.packetRssi();
    Serial.print("Left: ");
    Serial.println(joyL);
    Serial.print(" Right: ");
    Serial.println(joyR);
a separator would help... if joyL is 54 and joyR is 321, you are sending "54321"... how are you going to unpack that on the other end? it could have been 54 and 321 but why not 543 and 21 ? ...
send as "<X,Y>" for example then you can parse to ensure there is the start and end marker and the comma is the separator or send the binary values if you want something compressed
for an example of transmitting multiple data values in a structure using LoRa P2P see need-advice-on-a-home-project
Be very careful changing the syncword from the default, the datasheets might imply you can use whatever you want but it just ain't the case.
Some synwords are leaky, and let packets with different syncwords through.
Some syncwords dont work.
Some syncwords can reduce LoRa sensitivity.
Some syncwords may not be compatible with SX126X and LLCC68 LoRa devices
