I'm trying to use a Leonardo with Spark Fun MIDI shield to connect a MT-32 to a Mac to play classic video games.
This is the shield:
This is the MT32: http://www.vintagesynth.com/roland/mt32.php
I've been messing with the UsbMIDI library, but I can't figure out how to pass just every event in two directions between USB MIDI and Serial 1. This is my code now, but it does not work.
I do see the Leonardo appear in the Apple MIDI tool.
What am I doing wrong?
Also a mystery: why is there no setup or begin command for USB midi? How to give the device a custom name for example? Does the library auto-setup when you include it?
Serial MIDI and USB MIDI use different data formats. You can't simply copy the bytes from one to the other, you need a parser that understands the content of the MIDI messages to be able to convert it to the correct format before sending it from serial to USB and vice versa.
You could use this MIDI routing example: Control Surface: MIDI_Pipes-Routing.ino
You probably don't need the loopback on USB, so you can just remove that line from the setup and decrease the number of pipes from 3 to 2.
The MIDIUSB library registers itself with the USB stack in its constructor, which runs before the setup function.
Stupid, I accidentally started 1.6.13, in 1.8.13 it works. But not completely. The tones from the games are played now, but the Midi-CC messages that setup the MT32 to have the nice resonant filter instruments loaded prior to the game start don't pass through. So now Space Quest sounds like it runs on crappy general MIDI.
The MIDI routing example doesn't distinguish between Note and CC messages, so if the notes get through, so should the CC messages.
I'm not familiar with classic games etc. but are you sure that the MIDI connection is set up correctly before it starts sending the CC messages in the setup? Maybe it sends those CC messages first, then opens the correct MIDI port and then sends the notes for the music?
Try using a MIDI monitor (e.g. Loading...) to see if you can control the instruments and effects yourself by sending CC and Note commands to the Arduino manually.
Do you know how long these SysEx messages are? If they are longer than 128 bytes they won't fit in the buffer and won't get transmitted.
The best solution is to try the latest development version of the Control Surface library, it can send and receive SysEx messages of any length. You'll have to remove the ~/Arduino/libraries/Control-Surface-master folder and replace it with the new-input version you can download here: GitHub - tttapa/Control-Surface at new-input
If you don't want to use the latest version, you can change the maximum SysEx size in the settings for the master version you have installed right now:
You'll need quite a bit of RAM for these buffers, don't make them too large.
What is strange though, normally the MT32 has blinking LED's indicating incoming MIDI, and those don't blink at all, not even the first fraction of a second.
When I increase the buffer size to 512 it does seem to make the LED blink a few times, but less than with my Firewire MIDI interface I usually use.
