Hi all, I have a Freenove ESP32 Board: dual-core 32-bit microprocessor, up to 240 MHz, 4 MB Flash, 520 KB SRAM.
I ran this display related sketch on it and it ran fine:
#include <TFT_eSPI.h>
#include <SPI.h>
#include "jpeg1.h"
#include "jpeg2.h"
#include "jpeg3.h"
#include "jpeg4.h"
#include "jpeg5.h"
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
void setup(){
Serial.println("Start");
tft.init();
tft.setRotation(1);
tft.setSwapBytes(true);
void loop(){
tft.pushImage(0, 0, 320, 240, jpeg1);
delay(150);
tft.pushImage(0, 0, 320, 240, jpeg2);
delay(150);
tft.pushImage(0, 0, 320, 240, jpeg3);
delay(150);
tft.pushImage(0, 0, 320, 240, jpeg4);
delay(150);
tft.pushImage(0, 0, 320, 240, jpeg5);
delay(150);
As you can see, there are 5 JPEG files.
Later, I modified the sketch to handle 15 JPEGs.
The Arduino IDE then reported there wasn’t enough room on my board. Google suggested using an external SPI flash chip (W25Q64).
I later got an external flash chip and tested it with this demo sketch shared by a YouTube tutorial. That sketch is below:
ESP32 External SPI Flash Demo
esp32-ext-flash-demo.ino
Demonstrates use of W25Q64 Flash memory module
Uses ESP32-S3 DevKit1
Uses SPIMemory Library
1 - Read Flash ID
2 - Read Flash Capacity
3 - Erase 4kB sector
4 - Write and Read
DroneBot Workshop 2025
https://dronebotworkshop.com
// Include Required Libraries
#include <SPI.h>
#include <SPIMemory.h>
// --- Your wiring on ESP32-S3 DevKitC-1 ---
static const int PIN_SCK = 12; // CLK
static const int PIN_MISO = 13; // DO -> MISO
static const int PIN_MOSI = 11; // DI -> MOSI
static const int PIN_CS = 10; // CS
SPIFlash flash(PIN_CS);
delay(200);
Serial.println("\n=== W25Q64 Quick Test ===");
SPI.begin(PIN_SCK, PIN_MISO, PIN_MOSI, PIN_CS);
if (!flash.begin()) {
Serial.println("Flash NOT detected. Check 3V3, GND, CS, and wiring.");
while (1) delay(10);
// NEW: getJEDECID() returns a 32-bit value like 0xEF4017 for W25Q64
uint32_t jedec = flash.getJEDECID();
uint8_t manufacturer = (jedec >> 16) & 0xFF;
uint8_t memType = (jedec >> 8) & 0xFF;
uint8_t capacityCode = jedec & 0xFF;
Serial.printf("JEDEC ID: 0x%06lX (MFG=0x%02X TYPE=0x%02X CAP=0x%02X)\n",
(unsigned long)jedec, manufacturer, memType, capacityCode);
Serial.printf("Reported capacity: %lu bytes\n", (unsigned long)flash.getCapacity());
const uint32_t addr = 0x00000; // sector 0
Serial.println("Erasing 4KB sector @ 0x000000...");
if (!flash.eraseSector(addr)) Serial.println("Erase FAILED");
// NEW: make it non-const for writeCharArray (or use writeAnything)
char msg[] = "Hello from ESP32-S3 + W25Q64!";
bool okW = flash.writeCharArray(addr, msg, sizeof(msg)); // includes '\0'
char buf[sizeof(msg)] = { 0 };
bool okR = flash.readCharArray(addr, buf, sizeof(buf));
Serial.printf("Write: %s Read: %s\n", okW ? "OK" : "FAIL", okR ? "OK" : "FAIL");
Serial.print("Data: ");
Serial.println(buf);
void loop() {}
This demo works for basic write/read operations.
My goal now:
I want to download large .h files (images) onto the W25Q64 and access them from the ESP32, rather than embedding them in the main sketch.
Questions:
Can someone guide me to a tutorial showing how to upload large files onto an external SPI flash like the W25Q64?
Is there a Windows-based GUI tool where I can drag-and-drop files into a flash memory like the W25Q64?
Thanx for the replies!
