I'm trying a SevSeg code I got from this post which suppose to display a counting number but all I got on the display is steady "88". I'm using Arduino Leonardo and wired the correct pins to each of the pins on the 2-digit 7-segment display.
/* SevSeg Counter Example
Copyright 2017 Dean Reading
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
This example demonstrates a very simple use of the SevSeg library with a 4
digit display. It displays a counter that counts up, showing deci-seconds.
#include "SevSeg.h"
SevSeg sevseg; //Instantiate a seven segment controller object
byte numDigits = 2;
byte digitPins[] = {};
byte segmentPins[] = {2, 3, 4, 5, 6, 7, 8};
bool resistorsOnSegments = false; // 'false' means resistors are on digit pins
byte hardwareConfig = COMMON_CATHODE; // See README.md for options
bool updateWithDelays = false; // Default. Recommended
bool leadingZeros = false; // Use 'true' if you'd like to keep the leading zeros
sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins, resistorsOnSegments, updateWithDelays, leadingZeros);
sevseg.setBrightness(90);
static unsigned long timer = millis();
static int Seconds = 0;
if (millis() - timer >= 1000) {
timer += 1000;
Seconds++; // 1000 milliSeconds is equal to 1 Second
if (Seconds == 100) { // Reset to 0 after counting for 100 seconds.
Seconds=0;
sevseg.setNumber(Seconds, 1);
sevseg.refreshDisplay(); // Must run repeatedly
I can't seem to find any other sample code using a 2-digit 7-segment display. Anyone?
Well, the point is that unless you specify the digit pins, it will absolutely not work, so that is from where you must start. Specify the digit pins, figure out what the two dots mean and progress from there.
2n3904:
Well, that's your claim, but if it's not working, either the wiring or the code or both - are wrong. So I think it is time for a picture of your layout, taken outside in daylight but not full sun so each part can be seen and perhaps pictures of the "88" and dots on the display.
Paul__B:
You're right I misunderstood the digitPins as I don't usually specify anything on it when using a single-digit segment display.
