couldn't get it to work, read as always on
Exactly which pin do you mean ?
Is it marked SS on the board ?
How are you reading the state of the pin and what do you have connected to the board ?
yep, the one marked ss, D17, PB0 Atmega32u4,
pinMode(Pin_X, INPUT);
const uint8_t Pin_X = 17;
boolean pressX = !digitalRead(Pin_X);
connected to a button which shorts to ground
You have to include all the code you have written in your question, otherwise no one can give a meaningful answer!
I can only see that you have to change pinMode(Pin_X, INPUT); to pinMode(Pin_X, INPUT_PULLUP); if you connected to a button which shorts to ground.
#include <XInput.h>
#include <Smoothed.h>
const uint8_t Pin_HL = A4;
const uint8_t Pin_VL = A5;
const uint8_t Pin_HR = A11;
const uint8_t Pin_VR = A0;
const uint8_t Pin_A = 7;
const uint8_t Pin_B = 1;
const uint8_t Pin_Y = 0;
const uint8_t Pin_LB = 11;
const uint8_t Pin_RB = 6;
const uint8_t Pin_LT = A8;
const uint8_t Pin_RT = A6;
const uint8_t Pin_LM = 5;
const uint8_t Pin_RM = 3;
const uint8_t Pin_VA = A3;
const uint8_t Pin_HA = A2;
const uint8_t Pin_3 = A1;
boolean pressUP = false;
boolean pressDOWN = false;
boolean pressLEFT = false;
boolean pressRIGHT = false;
boolean pressHOME = false;
boolean pressBACK = false;
boolean pressSTART = false;
Smoothed <int> VAValue;
Smoothed <int> HAValue;
Smoothed <int> threeValue;
Smoothed <int> RTValue;
pinMode(Pin_A, INPUT_PULLUP);
pinMode(Pin_B, INPUT_PULLUP);
pinMode(Pin_Y, INPUT_PULLUP);
pinMode(Pin_LB, INPUT_PULLUP);
pinMode(Pin_RB, INPUT_PULLUP);
RTValue.begin(SMOOTHED_AVERAGE, 10);
VAValue.begin(SMOOTHED_AVERAGE, 10);
HAValue.begin(SMOOTHED_AVERAGE, 10);
threeValue.begin(SMOOTHED_AVERAGE, 10);
XInput.setRange(JOY_LEFT, 0, 0);
XInput.setRange(JOY_RIGHT, 0, 0);
XInput.begin();
boolean pressA = !digitalRead(Pin_A);
boolean pressB = !digitalRead(Pin_B);
boolean pressY = !digitalRead(Pin_Y);
boolean pressLB = !digitalRead(Pin_LB);
boolean pressRB = !digitalRead(Pin_RB);
int HLValue = analogRead(Pin_HL);
int VLValue = analogRead(Pin_VL);
int HRValue = analogRead(Pin_HR);
int VRValue = analogRead(Pin_VR);
int LTValue = analogRead(Pin_LT);
//int RTValue = analogRead(Pin_RT);
RTValue.add(analogRead(Pin_RT));
VAValue.add(analogRead(Pin_VA));
HAValue.add(analogRead(Pin_HA));
threeValue.add(analogRead(Pin_3));
//int VAValue = analogRead(Pin_VA);
//int HAValue = analogRead(Pin_HA);
//int threeValue = analogRead(Pin_3);
int HA = HAValue.get();
int VA = VAValue.get();
int three = threeValue.get();
HLValue = map(HLValue, 0, 899, 0, 1023);
int RT = RTValue.get();
RT = 1023-RT;
LTValue = map(LTValue, 62, 1023, 0, 255);
RT = map(RT, 166, 923, 0, 255);
if (HA<1020 && HA>=900){
pressRIGHT = true;
pressLEFT = false;
} else if (HA>=1020) {
pressRIGHT = false;
pressLEFT = true;
pressRIGHT= false;
pressLEFT = false;
if (VA>=1000 && VA<=1009){
pressUP = false;
pressDOWN = true;
} else if (VA>=300) {
pressUP = true;
pressDOWN = false;
pressUP= false;
pressDOWN= false;
if (three>=990 && three<1000){
pressHOME = true;
pressBACK = false;
pressSTART = false;
} else if (three>=1000 && three<1010){
pressHOME = false;
pressBACK = false;
pressSTART = true;
} else if (three>=1010){
pressHOME = false;
pressBACK = true;
pressSTART = false;
pressHOME= false;
pressBACK= false;
pressSTART= false;
//XInput
XInput.setButton(BUTTON_A, pressA);
XInput.setButton(BUTTON_B, pressB);
XInput.setButton(BUTTON_X, pressX);
XInput.setButton(BUTTON_Y, pressY);
XInput.setButton(BUTTON_LB, pressLB);
XInput.setButton(BUTTON_RB, pressRB);
XInput.setJoystick(JOY_LEFT, HLValue, VLValue);
XInput.setJoystick(JOY_RIGHT, HRValue, VRValue);
XInput.setTrigger(TRIGGER_LEFT, LTValue);
XInput.setTrigger(TRIGGER_RIGHT, RT);
XInput.setDpad(pressUP, pressDOWN, pressLEFT, pressRIGHT);
XInput.setButton(BUTTON_LOGO, pressHOME);
XInput.setButton(BUTTON_BACK, pressBACK);
XInput.setButton(BUTTON_START, pressSTART);
uint8_t bigRumble = XInput.getRumbleLeft();
uint8_t smallRumble = XInput.getRumbleRight();
analogWrite(Pin_LM, bigRumble);
analogWrite(Pin_RM, smallRumble);
//test
also changing to input pullup doesn't help, it was already that before and it was STILL stuck on being "pressed"
I suggest that you post the simplest possible sketch that reads the pin and prints its state with no other pins involved and reduce your project hardware to the same level
returns one, don't think i haven't tried that
Please post the code and schematic that produces that result
void setup(){
pinMode(17, INPUT_PULLUP);
pinMode(13, INPUT_PULLUP);
void loop(){
Serial.print("Pin 17: ");
Serial.println(!digitalRead(17));
Serial.print("Pin 13: ");
Serial.println(!digitalRead(13));
Result :
23:46:08.667 -> Pin 17: 1
23:46:08.667 -> Pin 13: 0
23:46:08.667 -> Pin 17: 0
23:46:08.715 -> Pin 13: 0
23:46:08.715 -> Pin 17: 0
23:46:08.715 -> Pin 17: 1
23:46:08.763 -> Pin 13: 0
23:46:08.763 -> Pin 17: 1
23:46:08.763 -> Pin 17: 0
Schematic :
literally nothing the board on it's own
can you tell me where the resistor i need to remove is? can't find it on my micro, can i just remove the led then?
No need to remove anything. Treat the LED and the resistor as pulldown and wire the switch between +5 V and SS. After setting pin mode to input, USB serial code will still try to turn the LED on and off, but will toggle the internal pullup instead. The LED+resistor shoud be stronger.
(untested)
late at night for me so hard finding it, where's that on the micro?
wait is that why it's outputting "HIGH"?
wait but, it's LEDs are diodes how should the 5v trigger PB0?
Oh my god. ok i've proper woken up and you mean i wire the switch with 5v instead of ground yea? i don't think it's possible, the switch is on a PCB, which is connected to a pcb with the micro.
there a way i could use ground instead still?
i could switch to either pin 9 or 10 but i'm reserving them for a potential 2.4ghz upgrade
