How to use a micro sd card reader on a pcb
As part of a pcb with other stuff on it, I need a micro sd card reader that will transmit data via spi. To save money and space I can't use one of the premade breakout boards. How would i hook up a plain micro sd card plug such as the TF-115 to a microcontroller? looked around online for quite a while but couldn't find anything on this other than how to use a sd card breakout board such as the adafruit version. If someone knew where to find a resource that explained the breakout board in depth that would also be fine, I could figure the rest out myself.
can be helpful. if it is - mark as solution
The tutorial you linked and the easyeda model have different pin names. Sorry for not being able to figure it out myself, i'm new to electronics but could you explain which pins in the tutorial would equal to which pins in easyeda (from the attached image)
connect what you recognize and show result.
Sorry but I dont understand what you want me to do. Are you asking which pins i already know are the same? If so i only know shell which isn't to do with the sd card and vdd which is self explanatory as well as vss. Other than that i don't know any of the pins.
3
here is the pin names from the tutorial if you want it
EasyEDA part:
SCHLIB_TF-115 SPI Micro SD Card Holder_2022-04-20.zip (1.3 KB)
