I need to use the MCP2120 infrared encoder/decoder, this chip requires a clock of 7.3728 MHz. Is there any way I can use Arduino to output a clock source?
hi
the simplest solution is to put a crystal of that value on the IR chip itself.
D
It is possible to sacrifice a PWM and make a timer clock a pin, but its period can only be integer multiples of your Arduino period. 7.3728MHz is not one of them. You could make 8MHz, but that is far enough off that I would expect it to be filtered out be the remote encoder/decoder.
I noticed that there are 2 pin and 4 pin crystal oscillator, what’s the difference?
2 pin devices are just the crystal resonator. 4 pin devices take power and ground and make a TTL level oscillating signal on the output.
Thanks! What does Arduino use? Resonator? What am supposed to use here? Or I can use either of them.
The microchip.com MCP2120 datasheet is a little vague about the OSCx pins, but I think there are enough clues there. It shows a photo of a development board with a 2 pin crystal with tiny capacitors on each lead. The pin description describes OSC1 and OSC2 for using a crystal, and also marks OSC1 as CLKIN when using an external clock. Looks like you could go either way. It has the circuitry to use a 2 pin crystal, but if you just have a 4 pin oscillator you could run its output into the OSC1/CLKIN pin.
The MCP2120/MCP2150 developer's kit user's guide shows a crystal on OSC1 and OSC2 with 18pF capacitors to ground from each side of the crystal. I'd go with that.
All hail to power of googling a part number!
