on Gammon's page (plus having the crystal connected).
From arduino IDE I select the new serial port and choose the upload.
Using Port : \\.\COM23
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done. Thank you.
I don't understand what am I doing wrong..
Going back to the connection to my Uno and uploading a new sketch that outputs serial data, connecting the FTDI and using the serial monitor of the IDE I can see the output, but if I try to upload a sketch it stops at " Overriding Baud Rate : 57600" and the led RX on the adapter turns on still like everything frees. Removing the crystal the same message of above appears.
Does anyone have any suggestions to help me understand?
ChilliTronix:
So if you connect it up there is a sketch loaded which outputs serial?
Perhaps there is an issue with your reset line.
Yes, currently I loaded the "ASCII Table" example and as soon as I open the serial monitor of the IDE.
The reset line is connected via 0.1 uF capacitor.
I also took away the crystal and the capacitor to have the exact same config as the image from Gammon, but nothing changes..
Ah... If you used Nick Gammon's bootloader sketch with a Lilypad bootloader that will be an internal crystal setup and sometimes the serial speed can be a bit flaky.
If you were seeing serial output from your sketch then I think the problem lies with your RESET circuit. If there's a DTR pin on your FTDI, try using that instead of RTS.
And in general what is now setup. External or internal oscillator? What frequency? What baudrate? What fusbits? (Sorry for my google translator english ;))
I had to use a 1.0 uF monolithic cap on my reset with the RTS* on my FT-232-R. The interface was purchased from DigiKey. It is an 8 pin device and brings out the TxD and RxD LED pins as CBUS0 and CBUS1. With the 1.0 uF cap, I am now able to load my custom-designed Arduino clone every time.
Dear all,
I was able to fix the issue and finally upload the sketches with my FTDI.
I had to re-burn the bootloader with Gammon's Atmega_Board_Programmer and choosing the ATmegaBOOT_168_atmega328_pro_8MHz_hex.
