Despite my best efforts, I have been unable to upload any sketches using my FTDI USB device.
The FTDI device I am using happily uploads sketches to any of my Arduino Pro Mini boards, but refuses to do the same with the breadboard UNO, and I cannot figure out why this is.
I have tried setting the FTDI board to either 5V or 3.3V (via onboard jumper)
I have also tried powering the breadboard externally and disconnecting the VCC pin on the FTDI device.
Sadly, none of these things made any difference.
Below are the pinouts I have been using (FTDI Device - Breadboard UNO).
DTR - Reset (pin 1) via 0.1uF capacitor
RX - TX (pin 3)
TX - RX (pin 2)
VCC - VCC
CTS - Not connected
GND - GND
When I attempt to upload, the sketch complies and then I see "Uploading", but that's where it stays, until it eventually times out and displays a whole lot of error messages.
Below is a subset of those error messages.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8d
avrdude: ser_recv(): read error: The I/O operation has been aborted because of either a thread exit or an application request.
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8d
avrdude: ser_send(): write error: sorry no info avail
avrdude: ser_recv(): read error: Access is denied.
I should add, I can successfully upload a sketch to the breadboard UNO when using an Arduino UNO with the chip removed as the programmer.
For both setups I have the board set to "Arduino Uno" in the Arduino IDE (v1.8.13)
Are there any different settings that need to be used?
