I am using a flex sensor to control a servo with the code below. I would like to add an if statement so that the servo doesn't move unless the flex sensor's value is above 725. (I am hoping that by doing this the servo will stop twitching when everything is at rest). I don't know how to add the if statement correctly. I tried the following but it didn't work. Can anyone tell me how to add this if statement correctly?
I have already used serial.print in previous code. That's how I got 722 and 880 as my input values. I know those values are good because if I take out the if statement and just use pinkyservo.write(pinkyflex) it works fine.
I don't understand why the if statement is not working.
By that I mean with those values the servo acts accordingly based on the sensors flex when mapped as "pinkyflex =map(pinkyflex, 722, 880, 6, 179);" I wanted to add the if statement because the servo twitches a little when everything is at rest. The flex sensor's resting value is ruffly 722 but it does fluctuate a little, which I believe is what is causing the servo to twitch.
I was hoping that by adding if (pinkyflex > 725) it would allow for the slight fluctuation in the sensor's resting value.
If pinkyflex is 722, then it becomes 6. So pinkyflex isn't going to be greater than 179 when your if-statement executes. A Serial.print() statement right before the if-statement would have illustrated that.
Thank you James C4S! That last statement is what I needed for the lightbulb to click on. Simple solution. I was using the original input values for the if statement instead of the new mapped values of 0 and 179. The code below works great. No servo twitch!
