How to use MPU9250 multiple sensors in following code
Here is my code and their it is possible to retrieve value for one sensor. How can I modify it for multiple sensors
#include <Wire.h>
#define SerialPort Serial
#include <SparkFunMPU9250-DMP.h>
MPU9250_DMP imu;
MPU9250_DMP imu2;
double roll , pitch, yaw;
long int pre_ts=0;
SerialPort.begin(115200);
if (imu.begin() != INV_SUCCESS)
while (1)
SerialPort.println("Unable to communicate with MPU-9250");
SerialPort.println("Check connections, and try again.");
SerialPort.println();
delay(3000);
imu.setSensors(INV_XYZ_GYRO | INV_XYZ_ACCEL | INV_XYZ_COMPASS);
imu.setGyroFSR(250); // Set gyro to 2000 dps
// Accel options are +/- 2, 4, 8, or 16 g
imu.setAccelFSR(2); // Set accel to +/-2g
imu.setLPF(10); // Set LPF corner frequency to 5Hz
imu.setSampleRate(10); // Set sample rate to 10Hz
imu.setCompassSampleRate(50); // Set mag rate to 10Hz
pre_ts=millis();
if ( imu.dataReady() )
imu.update(UPDATE_ACCEL | UPDATE_GYRO | UPDATE_COMPASS);
Serial.println("\n\n");
printIMUData(millis()-pre_ts);
pre_ts=millis();
delay(100);
void printIMUData(long int dt)
float accelX = imu.calcAccel(imu.ax);
float accelY = imu.calcAccel(imu.ay);
float accelZ = imu.calcAccel(imu.az);
float gyroX = imu.calcGyro(imu.gx)/57.3;
float gyroY = imu.calcGyro(imu.gy)/57.3;
float gyroZ = imu.calcGyro(imu.gz)/57.3;
float magX = imu.calcMag(imu.mx);
float magY = imu.calcMag(imu.my);
float magZ = imu.calcMag(imu.mz);
//Euler angle from accel
pitch = atan2 (accelY ,( sqrt ((accelX * accelX) + (accelZ * accelZ))));
roll = atan2(-accelX ,( sqrt((accelY * accelY) + (accelZ * accelZ))));
// yaw from mag
float Yh = (magY * cos(roll)) - (magZ * sin(roll));
float Xh = (magX * cos(pitch))+(magY * sin(roll)*sin(pitch)) + (magZ * cos(roll) * sin(pitch));
yaw = atan2(Yh, Xh);
roll = roll57.3;
pitch = pitch
57.3;
yaw = yaw*57.3;
//Serial.println("pitch" + String( pitch) );
Serial.println(String( roll));
//Serial.println("yaw" + String( yaw ));
thaminduanusara22:
I think the library uses the I2C/TWI/Wire interface which allows two devices to share the I2C bus. You will have to investigate the library to see how to tell it which address to use.
If you want more than two devices you will need to use the SPI interface (major library modifications) or modify the library to switch one device at a time to the default address and have the others switched to the alternate address.
How many devices did you want to support?
