How to use PORTD ?
Dear all,
Currently I am trying to run two stepper Motors at the same time on my ArduinoMega. As this is not possible with stepper.h library I use digitalWrite for each pin.
To simplify my code I tried to substitute a set of digitalwirte commands with an PORTD command, but this failed.
I tried to programm simple test program using PORTD command but it does not work.
Please help me finding the problem
Thanks a lot
christian
void setup(){
DDRD = B11111100;  // sets Arduino pins 3 to 7 as outputs, pin 0 as input
pinMode(3, OUTPUT);
void loop(){
Serial.println("low");
PORTD = B00000000; //this does not work
delay(3000);
Serial.println("high");
PORTD = B11111100;
delay(3000);
Serial.println("HIGH PIN");
digitalWrite(3, HIGH);  // this works fine
delay(3000);
Serial.println("low PIN");
digitalWrite(3, LOW);
delay(3000);
pinMode(3, OUTPUT);
Well on the Uno this would be pins 2 to 7, not 3 to 7, but on the Mega the port/pin mapping
is utterly different, and portD covers arduino pins 21,20,19,18 and 38.
Look at pins_arduino.h for the mega variant in the sources and you'll see something like:
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
	// PORTLIST
	PE	, // PE 0 ** 0 ** USART0_RX
	PE	, // PE 1 ** 1 ** USART0_TX
	PE	, // PE 4 ** 2 ** PWM2
	PE	, // PE 5 ** 3 ** PWM3
	PG	, // PG 5 ** 4 ** PWM4
	PE	, // PE 3 ** 5 ** PWM5
	PH	, // PH 3 ** 6 ** PWM6
	PH	, // PH 4 ** 7 ** PWM7
	PH	, // PH 5 ** 8 ** PWM8
	PH	, // PH 6 ** 9 ** PWM9
	PB	, // PB 4 ** 10 ** PWM10
	PB	, // PB 5 ** 11 ** PWM11
	PB	, // PB 6 ** 12 ** PWM12
	PB	, // PB 7 ** 13 ** PWM13
	PJ	, // PJ 1 ** 14 ** USART3_TX
	PJ	, // PJ 0 ** 15 ** USART3_RX
	PH	, // PH 1 ** 16 ** USART2_TX
	PH	, // PH 0 ** 17 ** USART2_RX
	PD	, // PD 3 ** 18 ** USART1_TX
	PD	, // PD 2 ** 19 ** USART1_RX
	PD	, // PD 1 ** 20 ** I2C_SDA
	PD	, // PD 0 ** 21 ** I2C_SCL
	PA	, // PA 0 ** 22 ** D22
	PA	, // PA 1 ** 23 ** D23
	PA	, // PA 2 ** 24 ** D24
	PA	, // PA 3 ** 25 ** D25
	PA	, // PA 4 ** 26 ** D26
	PA	, // PA 5 ** 27 ** D27
	PA	, // PA 6 ** 28 ** D28
	PA	, // PA 7 ** 29 ** D29
	PC	, // PC 7 ** 30 ** D30
	PC	, // PC 6 ** 31 ** D31
	PC	, // PC 5 ** 32 ** D32
	PC	, // PC 4 ** 33 ** D33
	PC	, // PC 3 ** 34 ** D34
	PC	, // PC 2 ** 35 ** D35
	PC	, // PC 1 ** 36 ** D36
	PC	, // PC 0 ** 37 ** D37
	PD	, // PD 7 ** 38 ** D38
	PG	, // PG 2 ** 39 ** D39
	PG	, // PG 1 ** 40 ** D40
	PG	, // PG 0 ** 41 ** D41
	PL	, // PL 7 ** 42 ** D42
	PL	, // PL 6 ** 43 ** D43
	PL	, // PL 5 ** 44 ** D44
	PL	, // PL 4 ** 45 ** D45
	PL	, // PL 3 ** 46 ** D46
	PL	, // PL 2 ** 47 ** D47
	PL	, // PL 1 ** 48 ** D48
	PL	, // PL 0 ** 49 ** D49
	PB	, // PB 3 ** 50 ** SPI_MISO
	PB	, // PB 2 ** 51 ** SPI_MOSI
	PB	, // PB 1 ** 52 ** SPI_SCK
	PB	, // PB 0 ** 53 ** SPI_SS
	PF	, // PF 0 ** 54 ** A0
	PF	, // PF 1 ** 55 ** A1
	PF	, // PF 2 ** 56 ** A2
	PF	, // PF 3 ** 57 ** A3
	PF	, // PF 4 ** 58 ** A4
	PF	, // PF 5 ** 59 ** A5
	PF	, // PF 6 ** 60 ** A6
	PF	, // PF 7 ** 61 ** A7
	PK	, // PK 0 ** 62 ** A8
	PK	, // PK 1 ** 63 ** A9
	PK	, // PK 2 ** 64 ** A10
	PK	, // PK 3 ** 65 ** A11
	PK	, // PK 4 ** 66 ** A12
	PK	, // PK 5 ** 67 ** A13
	PK	, // PK 6 ** 68 ** A14
	PK	, // PK 7 ** 69 ** A15
So you'll see the pin mapping for low numbered arduino pins is all over the place. You would do
better to use portA, which maps to pins 22 to 29 contiguously. Several other ports map to contiguous
ranges of pins too.
This explains the behavior!
Thanks a lot for this fast response!
Try setting up the DDRD the old fashion way.
DDRD=0XFF;
PORTD=0XFF;
the you can toggle the PORTD using( &, /).
Example code.
#include<avr/io. h>
#include<util/delay. h>
Int main(void) {
DDRD=0XFF;
PORTD=0XFF;
For(;:wink: {
PORTD&=~(1<<PD3);
_delay_ms(500);
PORTD|=(1<<PD3);
return 0;
This code toggles a led on and off every 500ms.
newbie_2017:
What stepper motor drivers are you using?
Have you considered the AccelStepper or MultiStepper libraries?
The AccelStepper library can control several motors at the same time. And if you need the motors to move in a closely coordinated way then the MultiStepper library can do that.
I just use digitalWrite() in the code I have written to control 3 motors with Pololu A4988 stepper drivers.
...R
Stepper Motor Basics
Simple Stepper Code
