how to use standard c header files in arduino
I have a simple C library that looks like this:
//mycLib.h
#ifndef _MY_C_LIB_h
#define _MY_C_LIB_h
    typedef struct {char data1;
                    int data2;
                    } sampleStruct;
    extern void mycLibInit(int importantParam);
    extern void mycLibDoStuff(char anotherParam);
    extern void sampleStruct mycLibGetStuff();
#endif
//mycLib.c
sampleStruct _sample;
    //init stuff!
    //lets say _sample.data2 = importantParam
    //do stuff!
    //lets say _sample.data1 = anotherParam
    //return stuff,
    // lets say return _sample;
It works well when called from other test software. However, as part of another project, I have to include it in an Arduino project and compile it to work on Arduino Uno as well. Unfortunately, When I run my Arduino code that looks like this:
#include <mycLib.h>
  mycLibInit(0);
I get the following compile error:
code.cpp.o: In function setup': C:\Program Files (x86)\Arduino/code.ino:6: undefined reference tomycLibInit(int)'
I have read following threads:
but in all those cases the external library was in form of a c++ class with a constructor call in the Arduino code.
Is there a way to tell Arduino IDE that "hey this function is part of this C library" or, should I re-write my functionality into c++ classes? Its not my favorite solution because the same c-Module is being used in other projects. (I know I probably can use preprocessor directives to have the code in the same place but it is not a pretty solution!)
//mycLib.h
#ifndef _MY_C_LIB_h
#define _MY_C_LIB_h
#ifdef __cplusplus
extern "C"{
#endif
                    int data2;
                    } sampleStruct;
#ifdef __cplusplus
} // extern "C"
#endif
#endif
Thanks Coding Badly!
Before I see your reply or try it, I rewrote my module in CPP. It works fine in test software in visual studio, however, when included and compiled in ARduino it just does not work!
I dont get any compile errors, it compiles, gets uploaded to the board but simply does nothing! This is an issue that I have to track tomorrow... But
But about your answer, now I have another question, then how would you call public functions of this .h file from Arduino code? Can you please give me an example?
All I have seen is that ppl call a constructor from a class in their c library and then call their methods from it. would be current arduino work with it? Should I put the mylib.h and .c in Arduino Libraries folder or should I put them next to my arduino code file? maybe just using the c in the way you mentioned help me!
Thanks,
fetah
You are welcome.
fetah:
Just like in your original post.
Yes.
With a test sketch until the code is debugged then as a library.
