So I have this project that requires me to use this and I have no idea where to start! I went to the website to download the zip file for windows, after that I followed the direction on how to start the program but when I went go to the serial port as instructed but it was already set to COM 3 when the instruction book told me to set it to COM 1 I couldn't find a way to get it to that setting.
I have tried everything and tried googling but it has led me nowhere. Please help me!
I assume you are talking bout a SparkFun Redboard.
Com 3 is what you should see, and Windows was smart enough to do this for you. It will assign higher Com Port numbers to additional Arduinos you use. Com 1 and Com 2 are usually reserved for hardware serial ports.
This is not correct. Just select Com 3 and carry on.
A fix was pushed last week to enable the redboard for another user.
There may be a slight issue with the serial monitor so if you do use CREATE then please let us know if you have any issues with that aspect. in the CREATE EDITOR section.
