How to use the atoi() function?
Hi..
How do I use the atoi() function to convert a String such as my_string = "123" to an integer?
I tried atoi(my_string) but I get the following error
"cannot convert String to const char for argument '1' to int atoi(const *char)...
Post your whole code?
But just a tip - atoi works with char* strings, not the String class.
You need to convert your String object to a Character Array.
Thanks James.. that's what I needed.
Could you show my a code example? The documentation page doesn't have any.. I'm confused about what it means by "the supplied buffer".
  char buf[my_string.length()+1];
  my_string.toCharArray(buf, my_string.length()+1);
Need to add one since the string is null terminated.
Thanks a lot..
With the curent IDEs you should be able to use the below:
int value = my_string.toInt();
