how to use tower pro micro servo 9g sg90 with arduino ?
It's simple! there are lots of examples on line, try Arduino playground.
Here's a bit of code from one of my robot sketches.
#include <FastIO.h>
#include <I2CIO.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7,3, POSITIVE); // Set the LCD I2C address
Define constants and varibles
#include <Servo.h>
const int LMpwm=6,LMdir=8,RMdir=7,RMpwm=9; //Motor pins
int distance,cm,FRQ,TD,A,B,MotorTime,switches,action,Lspeed,Rspeed,Tilt;
long int randNumber,motorSpeed,TwirlTime;
float unit,val,bv,factor;
boolean go;
Servo servoScan;
// lcd.begin(16,2);
// battCheck();
// lcd.clear();
// lcd.setCursor(2,0);
// lcd.print("I am Waiting");
// lcd.setCursor(3,1);
// lcd.print("Wave me off");
pinMode(LMpwm, OUTPUT); // sets the digital pin as output
pinMode(LMdir, OUTPUT); // sets the digital pin as output
pinMode(RMdir, OUTPUT); // sets the digital pin as output
pinMode(RMpwm, OUTPUT); // sets the digital pin as output
go = true;
Lspeed=200;
Rspeed=200;
servoScan.attach(A0);
servoScan.write(90);
delay(200);
scan();
// * * * start of Main program * * * *
So you have to #include the library <Servo.h>
Attach it to a I/O pin with servoScan.attach(A0); Any pin will do!
and tell it where to move to with servoScan.write(90); values 0-180 approx?
Just play around with that see what happens......
Hope it helps.
Mel
Look at the Servo/Knob and Servo/Sweep sketches included in IDE. They cover the basics of driving a servo and the SG90 is an ordinary servo.
Just don't try to power more than one servo from the Arduino board itself. Servos can take a lot of current so it's best to use a separate power supply for them.
Steve
thank you
