The documentation says to short the pads in the VUSB box on the bottom of the nano to activate the USB 5v pin. But there are also two solder dots labeled VUSB on the top side. Will bridging either the top two dots or the bottom two pads do the trick? Or do you have to bridge both the top and bottom locations? Or only the bottom? I can't find anything about shorting the solder dots on the topside.
Bottom side only.
Regards
When then are the two solder dots labeled VUSB on the top of the Nano?
I discovered that either the bottom or the top VUSB dots can be soldered on the rev2 to wake up the 5 volt pin. See https://docs.arduino.cc/tutorials/nano-33-ble-sense-rev2/cheat-sheet
Sorry, I didn't pay attention that it's rev2. ![]()
