Hi All, I have just built a cnc machine, for me that was the easy part however, I have 12v DC supply unit, 4 Nema 23 steppers with 4 TB6600 drivers, I also have the Uno board with a cnc shield, I also have homing switches to fit on each axis (the electrics not so easy!!
I have been reading posts and looking at videos for a week and I am still not confident that I can undertake the electrical install without messing up therefore, does anyone have or aware of a wiring configuration /schematic for the above.
Grbl is only good for 3 steppers (the 4th is a clone and not independently controllable with grbl).
You could use the CNC shield with the TB6600 drivers but they, of course, can't plug into the shield. You will have to wire from the headers on the shield. My opinion is that it would not really be worth it.
Hi, thanks for your response, I will be using grbl, my main concern is that I can only see on the cnc shield connections for the 3 TB6600 drivers, XYZ . As I am using two steppers on the Y axis where or can I connect the 2nd driver for that stepper or do I wire them together from the one driver?
Or, do I do away withe the cnc shield all together and connect straight to the UNO .
Thanks in advance,
John.
The CNC shield has positions for 4 stepper drivers. To clone a driver (2 drivers for one axis) for Y axis, you connect the headers on the clone headers as shown below.
Thank you so much, this is certainly a learning curve for me! ….so if I jump the wires as suggested, can I also use the A.STEP/DIR pins on the left hand side of the board just above the 5V/GND pins as this is where the other TB6600 drivers are being connected?
At the library digging through a card catalog or on the phone to manufacturers or taking to other hobbyists like I did for 40 years before the internet.
