Hi there,
I’m trying to get a led to respond to a certain temperature (data obtained from Wunderground). Where do I write the code?
I tried it with:
void setled {
if (temp_c <= 10) {
Serial.println("De temperatuur is gelijk aan of beneden 10 graden");
digitalWrite(ledPin, HIGH);
else {
digitalWrite(ledPin, LOW);
But I keep getting the error: variable or field “setled” declared void
Here’s my complete code:
#include <ESP8266WiFi.h>
#ifndef min
#define min(x,y) (((x)<(y))?(x):(y))
#endif
#ifndef max
#define max(x,y) (((x)>(y))?(x):(y))
#endif
#include <ArduinoJson.h>
int ledPin = D0;
const char SSID[] = "*********";
const char PASSWORD[] = "*********";
// Use your own API key by signing up for a free developer account.
// http://www.wunderground.com/weather/api/
#define WU_API_KEY "***************"
// Specify your favorite location one of these ways.
//#define WU_LOCATION "NL/AMSTERDAM"
// US ZIP code
//#define WU_LOCATION ""
//#define WU_LOCATION "90210"
// Country and city
#define WU_LOCATION "Netherlands/Amsterdam"
// 5 minutes between update checks. The free developer account has a limit
// on the number of calls so don't go wild.
#define DELAY_NORMAL (5*60*1000)
// 20 minute delay between updates after an error
#define DELAY_ERROR (20*60*1000)
#define WUNDERGROUND "api.wunderground.com"
// HTTP request
const char WUNDERGROUND_REQ[] =
"GET /api/" WU_API_KEY "/conditions/q/" WU_LOCATION ".json HTTP/1.1\r\n"
"User-Agent: ESP8266/0.1\r\n"
"Accept: */*\r\n"
"Host: " WUNDERGROUND "\r\n"
"Connection: close\r\n"
"\r\n";
// We start by connecting to a WiFi network
Serial.print(F("Connecting to "));
Serial.println(SSID);
WiFi.begin(SSID, PASSWORD);
Serial.print(F("."));
Serial.println(F("WiFi connected"));
Serial.println(F("IP address: "));
pinMode(ledPin, OUTPUT);
static char respBuf[4096];
int setled();
// TODO check for disconnect from AP
// Open socket to WU server port 80
Serial.println(WUNDERGROUND);
// Use WiFiClient class to create TCP connections
WiFiClient httpclient;
const int httpPort = 80;
if (!httpclient.connect(WUNDERGROUND, httpPort)) {
Serial.println(F("connection failed"));
delay(DELAY_ERROR);
return;
// This will send the http request to the server
Serial.print(WUNDERGROUND_REQ);
httpclient.print(WUNDERGROUND_REQ);
httpclient.flush();
// Collect http response headers and content from Weather Underground
// HTTP headers are discarded.
// The content is formatted in JSON and is left in respBuf.
int respLen = 0;
bool skip_headers = true;
while (httpclient.connected() || httpclient.available()) {
if (skip_headers) {
String aLine = httpclient.readStringUntil('\n');
//Serial.println(aLine);
// Blank line denotes end of headers
if (aLine.length() <= 1) {
skip_headers = false;
else {
int bytesIn;
bytesIn = httpclient.read((uint8_t *)&respBuf[respLen], sizeof(respBuf) - respLen);
Serial.print(F("bytesIn ")); Serial.println(bytesIn);
if (bytesIn > 0) {
respLen += bytesIn;
if (respLen > sizeof(respBuf)) respLen = sizeof(respBuf);
else if (bytesIn < 0) {
Serial.print(F("read error "));
delay(1);
httpclient.stop();
if (respLen >= sizeof(respBuf)) {
Serial.print(F("respBuf overflow "));
Serial.println(respLen);
delay(DELAY_ERROR);
return;
// Terminate the C string
respBuf[respLen++] = '\0';
Serial.print(F("respLen "));
//Serial.println(respBuf);
if (showWeather(respBuf)) {
delay(DELAY_NORMAL);
else {
delay(DELAY_ERROR);
bool showWeather(char *json)
StaticJsonBuffer<3 * 1024> jsonBuffer;
// Skip characters until first '{' found
// Ignore chunked length, if present
char *jsonstart = strchr(json, '{');
//Serial.print(F("jsonstart ")); Serial.println(jsonstart);
if (jsonstart == NULL) {
Serial.println(F("JSON data missing"));
return false;
json = jsonstart;
// Parse JSON
JsonObject& root = jsonBuffer.parseObject(json);
if (!root.success()) {
Serial.println(F("jsonBuffer.parseObject() failed"));
return false;
// Extract weather info from parsed JSON
JsonObject& current = root["current_observation"];
const float temp_f = current["temp_f"];
Serial.print(temp_f, 1); Serial.print(F(" F, "));
const float temp_c = current["temp_c"];
Serial.print(temp_c, 1); Serial.print(F(" C, "));
const char *humi = current[F("relative_humidity")];
Serial.print(humi); Serial.println(F(" RH"));
const char *weather = current["weather"];
Serial.println(weather);
const char *pressure_mb = current["pressure_mb"];
Serial.println(pressure_mb);
const char *observation_time = current["observation_time_rfc822"];
Serial.println(observation_time);
// Extract local timezone fields
const char *local_tz_short = current["local_tz_short"];
Serial.println(local_tz_short);
const char *local_tz_long = current["local_tz_long"];
Serial.println(local_tz_long);
const char *local_tz_offset = current["local_tz_offset"];
Serial.println(local_tz_offset);
return true;
void setled {
if (temp_c <= 10) {
else {
