HRM - Peripheral Name
From an old/closed post - for reference...
Klaus_K
Aug '21post #2
Here is an example for a Heart Rate Service. The heart rate is simulated by reading A0.
  This example creates a BLE peripheral with a Heart Rate Service
  The circuit:
  - Arduino Nano 33 BLE / BLE Sense
  - Arduino Nano 33 IoT
  - Arduino Nano RP2040 Connect
  You can use a generic BLE central app, like BLE Scanner (iOS and Android) or
  nRF Connect (Android), to interact with the services and characteristics
  created in this sketch.
  Silicon Labs EFR Connect and Infineon/Cypress CySmart can decode Heart Rate Service.
  This example code is in the public domain.
My question is about the peripheral name seen by the iOS/android app.
Sometimes on my iOS app I see "Arduino HRM" and other times I see
"Arduino Nano 33 BLE".
I'm using iOS, in my case.
I want the peripheral name, to be what I want, in this case "Arduino HRM".
When I have a temp sensor, or otherwise, I don't want the peripheral name
to be arduino nano 33 ble, I want it to be temp sensor.
So, I guess, I want to know if it's possible to force the older system
to see my chosen peripheral name, in my arduino code.
Anyway, thanks for the hrm code referenced above.
You can set the name using
BLE.setDeviceName( BLE_DEVICE_NAME );
BLE.setLocalName( BLE_LOCAL_NAME );
Apps may remember the name and use a UUID to identify the Arduino it is connected to. So, when you try different sketches on the same Arduino you may see an old name. Depending on the app you may need to do a refresh to force it to read the name from the peripheral device again.
Thank you.
For this, and other commentary, your comments have been
very helpful for my learning.
