Hello to all!
I recently bought the model HT-CT62 that has integrated an ESP 32-c3 and a lora sx1262. I'm trying to use the RadioLib library to transfer data bias LoRa. The problem is that I am always getting the error "[SX1262] Initializing ... failed, code -2" . I checked the connections and they seem good. So I think it must be some code error. Here is the pinout:
Datasheet
And here is the code, I am using Platformio:
#include <Arduino.h>
#include <RadioLib.h>
// SX1262 has the following connections:
// NSS pin: 8
// DIO1 pin: 3
// NRST pin: 5
// BUSY pin: 4
SX1262 radio = new Module(8, 3, 5, 4);
// or using RadioShield
// https://github.com/jgromes/RadioShield
//SX1262 radio = RadioShield.ModuleA;
// or using CubeCell
//SX1262 radio = new Module(RADIOLIB_BUILTIN_MODULE);
// save transmission state between loops
int transmissionState = RADIOLIB_ERR_NONE;
volatile bool transmittedFlag = false;
// flag to indicate that a packet was sent
// this function is called when a complete packet
// is transmitted by the module
// IMPORTANT: this function MUST be 'void' type
// and MUST NOT have any arguments!
#if defined(ESP8266) || defined(ESP32)
ICACHE_RAM_ATTR
#endif
void setFlag(void) {
// we sent a packet, set the flag
transmittedFlag = true;
// initialize SX1262 with default settings
Serial.print(F("[SX1262] Initializing ... "));
int state = radio.begin();
if (state == RADIOLIB_ERR_NONE) {
Serial.println(F("success!"));
Serial.print(F("failed, code "));
Serial.println(state);
while (true);
// set the function that will be called
// when packet transmission is finished
radio.setPacketSentAction(setFlag);
// start transmitting the first packet
Serial.print(F("[SX1262] Sending first packet ... "));
// you can transmit C-string or Arduino string up to
// 256 characters long
transmissionState = radio.startTransmit("Hello World!");
// you can also transmit byte array up to 256 bytes long
byte byteArr[] = {0x01, 0x23, 0x45, 0x67,
0x89, 0xAB, 0xCD, 0xEF};
state = radio.startTransmit(byteArr, 8);
// counter to keep track of transmitted packets
int count = 0;
// check if the previous transmission finished
if(transmittedFlag) {
// reset flag
if (transmissionState == RADIOLIB_ERR_NONE) {
// packet was successfully sent
Serial.println(F("transmission finished!"));
// NOTE: when using interrupt-driven transmit method,
// it is not possible to automatically measure
// transmission data rate using getDataRate()
Serial.println(transmissionState);
// clean up after transmission is finished
// this will ensure transmitter is disabled,
// RF switch is powered down etc.
radio.finishTransmit();
// wait a second before transmitting again
// send another one
Serial.print(F("[SX1262] Sending another packet ... "));
String str = "Hello World! #" + String(count++);
transmissionState = radio.startTransmit(str);
transmissionState = radio.startTransmit(byteArr, 8);
And this is the .ini code:
[env:esp32-c3-devkitc-02]
platform = espressif32
board = esp32-c3-devkitc-02
framework = arduino
lib_deps = jgromes/RadioLib@^6.5.0
