Not entirely sure we are allowed to ask HTML questions in here???
Anyway, here we are...
I won't post the entire HTML for the webpage my ESP32 displays because it's all a bit long.
But, I need to change the colour of one line of text, so I wrote this script.... but it doesn't work.
Any obvious reason why?
page += "<script>\r\n";
page += "var col = 1\r\n";
page += "if (col > 1) {\r\n";
page += "<h4 style='color: #FF0000; font-size: 200px; margin-top: 120px; margin-bottom: 25px;' id=\"data\">""</h4>\r\n"; // Display the data in red
page += "} else {\r\n";
page += "<h4 style='color: #00FF00; font-size: 200px; margin-top: 120px; margin-bottom: 25px;' id=\"data\">""</h4>\r\n"; // Display the data in green
page += "}\r\n";
page += "</script>\r\n";
This single line works fine:
Bit stumped (it doesn't display the text at all)
I am only just starting out with HTML etc, so a lot of this comes from good old Google
How about adding that single line conditionally to the head ?
You are allowed, but there are better places for html.
I tend to use the TryIt editor to work out how to do these things before i add them to a webpage on a small MCU simply for easy of experimentation.
Not sure what you mean by add it to the head (I know what the head is).
I will continue to tinker....
If you have single line of HTML that works then try printing what you are sending from your sketch to the Serial monitor to see whether it matches the single line
The issue is the actual script
Nothing works between:
and
Yet, further down the HTML is this script that loads the live data...
page += "var x = setInterval(function() {loadData(\"data.txt\",updateData)}, 1000);\r\n";
page += "function loadData(url, callback){\r\n";
page += "var xhttp = new XMLHttpRequest();\r\n";
page += "xhttp.onreadystatechange = function(){\r\n";
page += " if(this.readyState == 4 && this.status == 200){\r\n";
page += " callback.apply(xhttp);\r\n";
page += " }\r\n";
page += "};\r\n";
page += "xhttp.open(\"GET\", url, true);\r\n";
page += "xhttp.send();\r\n";
page += "}\r\n";
page += "function updateData(){\r\n";
page += " document.getElementById(\"data\").innerHTML = this.responseText;\r\n";
page += "}\r\n";
This works fine. Not sure I see the difference
I'll confess to not being a javascript expert, but I've written enough of it that I'm pretty sure your syntax is wrong. Open the browser in Developer Mode (ctrl-shift-i in Chrome) and load that page. I'm positive it will show script errors.
What you want to do is certainly possible, but it would be a detailed explanation and I really don't think this is the forum for it.
HInt: you'll need to give the line of text an ID, get the element using that ID and change the color attribute. Similar to what you do here
Yea, this is the trouble when you learn by Google.... it might 'appear' to work fine
Here's a different way to format the code so it's easier (IMO) to read. This isn't a solution to your problem, just an example. It actually reads a temperature sensor and dynamically updates the screen.
It also does the variable substitution that you were asking about yesterday (puts the value of temp into the page).
char* buildPage(float temp)
const char *page =
"<head>\
<style>\
body{background-color:black; color:yellow;font-family:sans-serif;font-size:12}\
.status{margin-left:30vw;padding-left:1vw;background-color:darkslateblue; color:white;width:30vw;font-size:24}\
.control{margin-left:30vw;padding-left:1vw;background-color:darkslateblue; color:white;width:30vw;font-size:24}\
</style>\
<script>\
setInterval(function()\
getData();\
}, 5000); \
function getData() {\
xhttp.onreadystatechange = function() {\
if (this.readyState == 4 && this.status == 200) {\
document.getElementById('temperature').innerHTML =\
this.responseText;\
xhttp.open('GET', 'tempRead', true);\
xhttp.send();\
</script>\
</head>\
<body>\
<div id='temperature' class='status'>%5.1fF</div>\
<div class='control'>\
<form action='/updateSetpoint' method='GET'>\
<input type = 'button' id = 'increase' value= '+'>\
<input type = 'button' id = 'decrease' value= '-'>\
<input type='submit' value='Change Setpoint'/>\
</form>\
</div>\
</body>";
sprintf(pageBuffer, page, temp);
return pageBuffer;
BTW: there's an arduino library that keeps HTML in Flash/SD card and allows variable substitution. I have completely forgotten what it's called, but it makes this kind of stuff much easier.
kolaha
September 24, 2024, 12:13pm
9
baffled2023:
page += " }\r\n";
page += "};\r\n";
page += "}\r\n";
page += "}\r\n";
contain Javascript.
contain not java, A.K.A. empty condition
Tried it in the web developer..... didn't see any errors.
Not sure what that last post means.... I think you mean my text code isn't javascript?
kolaha
September 24, 2024, 12:34pm
11
<script></script>
allow no HTML between.
so at the end its looks like
<script>
var col = 1
if (col > 1) {
</script>
legit. no errors.
as far as i know there should be only a single script per page. You should include the other part in between those script tags
I did look up whether you could have more than one script and it said is was fine.
But... I can try it
This is the template processor I was thinking of... I think
The Arduino programming language Reference, organized into Functions, Variable and Constant, and Structure keywords.
You guys are solving the wrong problem!
Yes, there is an issue with the script's syntax. But even after fixing that, what he has won't work.
@baffled2023 here's an example of what you're trying to do. How to change the font color of a text using JavaScript?
Yea...
I think we have moved beyond my hobby brain. I just don't understand HTML etc enough to grasp this.
At the top of my HTML I have:
page += "<head><meta name=\"viewport\" content=\"width=device-width, user-scalable=no, initial-scale=1\">";
That should auto-scale the page to a mobile device (I believe), and yet it doesn't.
Thanks for all the advice anyhow
that so depends on the browser you are using. is there a </head> ?
As a recommendation i would change all \" within ".." to a ' which is the same for html, but greatly improves readability within a sketch.
anyway without the complete page it is all a tad hard to find what you did and how it does or doesn't work. Not that i will promise to go through it all though, i still recommend w3schools TryIt editor to check on functionality before incorporating it into a page.
The whole page...
server.on("/", []() {
page = "<!DOCTYPE html><html>";
page += "<head><meta name=\"viewport\" content=\"width=device-width, user-scalable=yes, initial-scale=1\">";
page += "<style>body {background-color: black;}</style></head><body>"; // Set up the webpage
page += "<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}</style></head>";
page += "<img src='https://www.google.co.uk/wp-content/uploads/2017/08/Logo.png'>";
page += "<h1 style='color: #FFFFFF; font-size: 120px; margin-top: 25px; margin-bottom: 5px' >Test text</h1>\r\n";
page += "<h2 style='color: #C0C0C0; font-size: 60px; margin-top: 5px; margin-bottom: 20px' >TIMING SYSTEM</h2>\r\n";
page += " }\r\n";
page += "};\r\n";
page += "}\r\n";
page += "}\r\n";
server.send(200, "text/html", page);
Had to change the webpage for obvious reasons.
This all works fine. The timer updates and I can control the page from my ESP32.
I wanted to be able to change the colour of the live changing timer value (data), depending on an external influence (e.g. the time value or a flag value)
kolaha
September 24, 2024, 2:56pm
19
if(Flag) page += "<h4 style='color: #FF0000; font-size: 200px; margin-top: 120px; margin-bottom: 25px;' id=\"data\">""</h4>\r\n";
else page += "<h4 style='color: #00FF00; font-size: 200px; margin-top: 120px; margin-bottom: 25px;' id=\"data\">""</h4>\r\n";
//or
page += "<h4 style='color: #";
if(Flag) page +="FF0000";
else page +="00FF00";
page +="; font-size: 200px; margin-top: 120px; margin-bottom: 25px;' id=\"data\">""</h4>\r\n";
baffled2023:
Though at a first glance both </body> & </html> as well as there being an extra </head> without <head>
These things will cause unpredictable behavior.
What @kolaha is showing is what i meant by my suggestion in #2
