i am connecting arduino with ITEAD 3g shield though it is a 3g shield i'm currently using 2g means GPRS(actually EDGE) mode . i'm trying with to connect http with at command. All my at command works as it should untill GET command. it stuck in GET command
my question is,
1 .If i want to seee the ip with "AT+IPADDR" it shows me a ip , does that means that it is connected with internet??
As i go untill GET command , does that means the problem only with the get command , the previous command are ok ??
I am trying in gateway mode... means with at cammands through serial . So actually there is no code. & the domain is provided by simcom . they give it in their at command manual. I have checked the address . there they installed a small web site.
